Supravox RTF64 design options (long) - Page 4 - diyAudio
Old 11th August 2006, 03:41 PM   #31
GM is offline GM  United States
GM's Avatar
Originally posted by schiller
I see that the measured T/S parameters from this site
http://www.yildiz.edu.tr/~ilkorur/speaker/supravox.txt
are much more different from these of the manufacturer. Has anybody else tried to measure them?
I haven't any experience with loydspeakers, could this kind of descrepancy between measured-published specs be typical?
Or in other words: should i take the published spes nicht for granded?
Thanks in advance
Konstantinos
Greets!
Not me, and yes, it's too often typical, though the industry as a whole considers +/- 10% exceptable, which these meet.
Anyway, the top sim is a T/S max flat using published specs and the bottom one is the measured specs in the same cab. It has marginally better acoustic efficiency, but the trade-off is somewhat degraded transient response which can be improved back to 'stock' with a minor increase in damping, so the spec differences are no big deal IMO for all but the perfectionists among us.
That said, it's not wise to assume that all driver published specs are within +/- 10% or that using them will be 'close enough' for max performance.
GM
File Type: jpg supravox 215 rtf64 published vs measured specs.jpg (66.3 KB, 169 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th August 2006, 06:34 PM   #32
Scottmoose's Avatar
A depressing thought on the whole.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Focal 2-way crossover design options focal7C Multi-Way 4 20th August 2008 02:56 AM
supravox 285gmf jensen +supravox fronthorn Jacobus Multi-Way 3 16th August 2006 12:15 PM
Audax 652 design options SndDoofus Multi-Way 0 22nd February 2005 06:13 AM
3-way design options goskers Multi-Way 7 22nd July 2004 06:41 AM
Copyright 1999-2017 diyAudio
