Supravox RTF64 design options (long)
Old 10th May 2006, 03:25 PM   #21
GM is offline GM  United States
GM's Avatar
Greets!
You're welcome!
Hmm, the procedure I have is a bit more complex and requires more info such as the OPT's Kva along with its primary and secondary DCR, so can't do a comparison.
Anyway, I didn't reverse engineer the Singular, but ignoring any Qts rise from OPI (which will increase the pipe's Q (Qp)), the RTF wants to 'feel' a ~8.778 ft^3 Vb if tuned to Vp = Fs. Factor in the QPI and it jumps to ~12 ft^3! A nfb SE amp wants to 'feel' a flat impedance though, so net Vb falls a bit to ~7.325 ft^3, but Fp rises to 108.5 Hz for the former and 88.8 Hz/~8.3 ft^3 for the latter. As you shrink Vb for a given Vp, F3 rises just like any other vented alignment.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th May 2006, 09:08 PM   #22
fred76 is offline fred76  Philippines
Hi GM,
As usual, I learn a lot from your posts even if some of the more heavy on theory arcane stuff is still beyond my grasp. Thanks!
fred
Old 12th May 2006, 04:56 PM   #23
GM's Avatar
Greets!
You're welcome! Sorry 'bout that, I figure if an explanation is to have any validity it must include at least some of the techno-babble it's derived from just in case it needs to be corrected and/or elaborated upon by others.
GM
Old 21st May 2006, 10:16 PM   #24
Ciu is offline Ciu  France
Default Some Other Boxes
Hello !
First, Sorry for my poor English vocabulary
Some other ideas for Supravox :
http://www.audiofanatic.it/Diffusori...TQWT215_1.html
http://www.yildiz.edu.tr/~ilkorur/speaker/supravox.htm
I've tested the supravox TQWT, this one with the front vent ; Quite nothing below 150hz !
Another idea in a sealed box, 42 liters, give a good response from 75hz ( my actual home system )
I'm working on a MLTL, around 92 liters, the preliminary tests seems to give the good way ....
R.C.
Old 29th June 2006, 10:31 AM   #25
felixx is offline felixx  Romania
felixx's Avatar
So.....you decided what enclosure you use?
I ask because I myself have the same difficulties in choosing the best enclosure but in my case the driver is 215RTF64Bicone.
Also I think an closed enclosure should work fine.I don't know how big it will be.......
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 29th June 2006, 10:39 AM   #26
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
The larger it is, the closer the driver will be to performing as it would in free air. The 215 will need a BIG sealed box. Going aperiodic might help there.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 29th June 2006, 10:59 AM   #27
felixx's Avatar
Scott....
But in this case isn't better into a baffle?
Something like this?
Old 29th June 2006, 12:13 PM   #28
Scott's MLTL posted recently seems like the best compromise to me now WRT size and performance. I mean the footprint is more manageble compared to the Tannoy type BR a few pages back. I'm interested in the Non-Bicone so the dims would be a bit larger than what he posted due to higher Vas.
Hi Scott,
Got your email. I just replied! Thanks!
fred
Old 4th July 2006, 06:48 PM   #29
schiller is offline schiller  Greece
I see that the measured T/S parameters from this site
http://www.yildiz.edu.tr/~ilkorur/speaker/supravox.txt
are much more different from these of the manufacturer. Has anybody else tried to measure them?
I haven't any experience with loydspeakers, could this kind of descrepancy between measured-published specs be typical?
Or in other words: should i take the published spes nicht for granded?
Thanks in advance
Konstantinos
Old 11th August 2006, 01:03 PM   #30
felixx's Avatar
"The 215 will need a BIG sealed box. Going aperiodic might help there".
So ....to obtain 40hz flat ....what dimensions and, how many of aperiodic ports do you think is necesary?
Some kind of that enclosure with Manger driver.....go well to 40hz is here:
http://www.cooltune.ch/index.html
http://www.cooltune.ch/Projects/Menhir01.htm
http://www.cooltune.ch/Projects/AMVMenhir2b.pdf
The project is complex...but I think is well made.The aperiodic port is nice maded.
Any thoughts?
Supravox RTF64 design options (long)Hide this!Advertise here!
Focal 2-way crossover design options focal7C Multi-Way 4 20th August 2008 03:56 AM
supravox 285gmf jensen +supravox fronthorn Jacobus Multi-Way 3 16th August 2006 01:15 PM
Audax 652 design options SndDoofus Multi-Way 0 22nd February 2005 07:13 AM
3-way design options goskers Multi-Way 7 22nd July 2004 07:41 AM
