#41 | |
Whew, way too many forums discussing the same subjects - it's hard to remember who said what, where. By "SI", I assume you mean Sonic Impact? While my preference for hollowstate amplification is well known, unless you're trying for rockconcert or movie theatre SP levels, 10watts or so of any kind of decent power should be quite adequate for the 126E's in most any enclosure, while retaining reasonable dynamic headroom. If you've had a chance to collate the posts on the Frugelhorn project information scattered among at least 3 forums, you'll be aware that it's still at the early stages of evolution - very exciting and at the same time humbling for those involved. Regardless of changes in details, the basic design concept will likely be maintained: a DIY open source design for compact BLH enclosure with rear mouth, and at least initially, adjustable CC to allow for driver experimentation. For optimum performance even in systems that will incorporate separate woofers/subs, whether driven through passive XO, or fully actively, compact horns of this design family will need corner reinforcement. With our brief session with the sub, we used the speaker outputs from the tubed amps (RH84 monoblocks in this case) into the high level inputs of the sub amp. We ran it both ways - in parallel (i.e. the horns ran "full range" and the sub rolled in at whatever setting we played with) and series (from the main amps to the sub amp, and connecting the horns to the speaker level output) One of the limiting uncertainties of the budget class of integrated plate sub amps is the quality and exact topology of the crossover networks, particularly the slope of the high level high pass output. Another is legibility and accuracy of calibration on the crossover frequency control. Anyway, we found the least obnoxious integration when dialed in anywhere between "60 - 80Hz". If I'm sounding less than enthusiastic about using a powered sub, at least for audio only - you're right, |
#42 |
frugal-phile(tm)
More pictures up, and a few comments on a comparison of the alpha build to the modified B-Horn reference.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#43 |
Banned
And, just so people done have to go back a few pages for the link dave is talking about here it is once again..
http://www.planet10-hifi.com/alpha121.html |
#44 |
Just thinking aloud from an aesthetic point of view dave, would this completely kill the design? Just looks a bit different and makes use of that nice rear slope..
"A squid eating dough in a polyethylene bag is fast and bulbous, got me?" |
#45 |
frugal-phile(tm)
Cool aesthetic, but you just wiped out the mouth
If you look at any rectangular RL-Horn the biggest areas available for mouth are the back & the sides. A horn this size has to corner loaded, so for simplicity using the back makes sense. Even thou the top part of the mouth in these may not be fully functional it does use the entire back. Ron Clarke is working on optimizing the mouth as much as possible, expect to see some crescents and don't be surprised if the bottom of the side panels extends back some more. dave
#46 |
I like the looks of Ropie's idea and you could add a square flared final segment. A bit tricky for the cuts and I know it would enlarge the footprint, but I'm a sucker for the sculpture look. In this case it would serve a good function too.
Everyone has a photographic memory. It's just that most are out of film. |
#47 | |
frugal-phile(tm)
dave
#48 |
Me likely. That is closer to what I envisioned from a hint you posted about a year ago about a Bhorn with a bigger mouth. That shape should be fun for Ron to get round output out of.
#49 |
Mightn't something like this help in the absence of a full mouth?
Again, it's just good to play with things a bit, even though I think this it's a very neat little design straight out of the box, as it were. I just know that Ron is going to come up with the goods anyway!
#50 |
diyAudio Editor
Ropie has a good design eye. If we can make his ideas work they are beautiful
| Page generated in 0.13811 seconds (73.66% PHP - 26.34% MySQL) with 11 queries |
