Fr125s Horn
Fr125s Horn
Old 25th April 2006, 04:41 PM   #11
GM is offline GM  United States
GM's Avatar
Greets!
Unless it's near/at a wall or corner, it needs to be at least 36" wide/tall for 80 Hz, though it can be made with wings and folded back a little to slightly narrow it to the eye and smooth the blend to the room. Another trick to fool the eye and improve blending to the room is to make it tapered on one side where the mean is 36" at the midpoint of its height.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th April 2006, 07:03 PM   #12
inrank is offline inrank  United Kingdom
inrank's Avatar
so what would be my best option for a PAWO sized cabinet or shall i just keep my existing ones.....
Old 26th April 2006, 05:50 PM   #13
inrank's Avatar
ok, having a think, instead of making a new enclosure, i could make a bass enclosure for ..
--one 8 Ohm 6 1/2" bass driver (on front)--
--two 4 Ohm 6 1/2 Bass drivers in paralel(on front)--
--one 8 Ohm 8" Bass driver (on the side)--
(could add a Passive Radiator aswell)
using the same width and depth of my standmounter and around 600mm tall. (it would be 20L in volume)
creating a 2 or 2.5 way with two enclosures with the FR125 crossing at around 80-100Hz
looking for mabye 40ish each for drivers (or 30 for the 4Ohm ones)
pic---Click the image to open in full size.
Old 27th April 2006, 01:24 PM   #14
GM's Avatar
Greets!
Don't know, I'm not set up to quickly reverse engineer to meet a specific size. FWIW, once you move away from a single FR125S and space is an issue, I recommend one of these bipole designs: http://www.planet10-hifi.com/boxes-CSS.html
GM
Old 27th April 2006, 01:27 PM   #15
inrank's Avatar
i like the bi pole idea but i only have around 30cm max from a wall to the rear and i wanted somthing (bass driver) a bit bigger, like the Extremis 6.8 but i dont have the funds.
Fr125s HornHide this!Advertise here!
Fr125s Bib cangaceiro99 Full Range 16 26th August 2008 06:16 AM
FR125S x2 (EU,UK) jimbo1968 Swap Meet 0 23rd November 2006 05:21 PM
CSS FR125S 2 way OB Rafal Full Range 19 10th October 2006 03:56 PM
css fr125s joe perry Full Range 5 10th May 2006 04:11 PM
