Horns Without Proper Placement? - diyAudio
Old 14th April 2006, 06:41 AM   #1
theseum is offline theseum  United States
Default Horns Without Proper Placement?
I am looking to put together a new stereo system really cheap (my old one died!) and am drawn to the t-class amps (cause they are cheap). Lots of people seem to like pairing them with loudspeakers based on horn enclosures, but, one of my requirements is that I can point the speakers out the window and listen to the outside. Should I forget about horns? Thank you!
Old 14th April 2006, 07:19 AM   #2
audiomanics's Avatar
Good horn-enclosures are anything but cheap .. If cheap is your goal, you should forget about them.. They're big too, normaly, so you can not hang them out of the window, easily..
For anything else: horns are the best (my humble opinion ;-)
Kees
Old 14th April 2006, 07:21 AM   #3
CLS is offline CLS  Taiwan
Outdoor application?
I'd think of PA speakers or the likes...
Old 14th April 2006, 02:43 PM   #4
Let me be clear: I want to be able to listen to them in my living room and have them sound as good as possible. That's my top priority. But their outdoor performence is also important to me.
From what I've been seeing it should be possible to build a pair of horns for very little money especially if I can scavenge the MDF...
Old 14th April 2006, 03:03 PM   #5
In that case: YES USE HORNS!!! (if you can find a handy mthrfckr that will mill the hornscales for less than no money) ..
I can tell you some handy trick for making nice horns although...
(formula's, excell-sheets etc.. you can find me, i'm sure)
Check the thread of Bas Horneman's hornspeakers..
Pictorial of an exponential/radial horn being made for me by a friend...
www.techgraphix.nl
Old 14th April 2006, 04:16 PM   #6
no xo is offline no xo  United States
I have dougle-hung windows at my house and the driver on my Fostex FE206E recommended horns is high enough to point them outside for barbeques and parties. Of course they sound better inside, but their loud enough to cover the neighborhood. Build horns and party. This is a great hobby.
Old 14th April 2006, 05:30 PM   #7
rcavictim's Avatar
Default Re: Horns Without Proper Placement?
What pray tell is a "t-class" amp?
T-ube (not cheap), T-ransistor (sounds dreadful if cheap),
How about an "iced t-class" amp? Cryogenic gain stages = lower noise. What does orange-pekoe sound like anyhow? Lipton leads to Leak!
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 14th April 2006, 07:43 PM   #8
Default Re: Re: Horns Without Proper Placement?
I would guess you know the answer here, but it's the Sonic Impact type of direction. Chip amps of sorts. I know their not all T-amps, but that's the idea. Very clean, extended and smooth. Especially considering the $$.
Cheers!
Old 14th April 2006, 07:54 PM   #9
rcavictim: "t-class" is a word that tnt-audio made up to refer to amps based on the Tripath chips, like the famous t-amp.
no xo: that is what I like to hear.
thanks everybody for humouring my ignorance.
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
proper choke placement dsavitsk Tubes / Valves 6 12th January 2006 09:50 PM
Looking for proper transformer. contaxchen Parts 0 15th September 2004 02:38 AM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright 1999-2017 diyAudio
