I was just checking out the drivers at parts-express and noticed that the Dayton DA135-8 5.25 inch woofer (part # 295-330) has a frequency response of, 50-15,000 Hz. Could this driver actually be used in a full range application?
Here's a link to the driver: http://www.partsexpress.com/pe/showd...number=295-330 These are the links to the specs at PE's website: http://www.partsexpress.com/pdf/295-330.pdf http://www.partsexpress.com/pdf/295-330g.pdf |
#2 |
Hmm...I've never thought about using the Daytons as fullrangers. The main problem why aluminum cone speakers usually cannot be used for higher frequency lies in their break-up nodes. However, looking at the cumulative spectrum decay graph of the DA175 at Zaph's site (www.zaphauiod.com), it looks like the resonances aren't too bad. The distortion figures are also within acceptable limits. I suppose the DA135 isn't substantially different from the DA175. The DA135 has a resonance peak at 9 KHz so my suggestion is to use a notch filter and listen to the result! If you try it out, please let me know! By the way: Keep in mind that these speakers have a bad dispersion characteristic, so listen to them on axis!
| 6.5" silver flute with 1 1/8" dayton silk dome tweeter | jadenlinkletter | Multi-Way | 10 | 28th February 2006 07:20 AM |
| Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? | tktran | Subwoofers | 2 | 14th August 2005 02:04 PM |
| Dayton RS180 vs Dayton 6.5" | kestrel200 | Multi-Way | 0 | 2nd May 2005 12:59 AM |
| Dayton 6" reference and dayton silk dome tweeter combo project...input? | nerd of nerds | Multi-Way | 4 | 2nd December 2004 05:36 PM |
| Dayton 5.25" AL vs. Dayton 5.25 paper for Lo-Mid opinions? | netgeek | Multi-Way | 6 | 14th May 2004 01:14 PM |
