Tivoli speaker - diyAudio
Old 2nd April 2006, 11:52 AM   #1
Kees is offline Kees  Netherlands
Kees's Avatar
Default Tivoli speaker
I bought a Tivoli Model One radio and am really suprised about the sound quality.
Any idea about what speaker is used?
Old 3rd April 2006, 10:48 PM   #2
Surprised pleasantly or otherwise?
I've wondered what was in there too.
Old 6th April 2006, 07:37 PM   #3
Kees's Avatar
I was suprised positively.
Looking for small speakers I found that there is a lot about the Tangband W3-871 S on the internet and I ordered 2 pieces.
I am planning to put them in a bass-reflex enclosure of 5.8L and tune this at 75Hz as this is what simulations advise.
Old 6th April 2006, 08:16 PM   #4
So what's in the Tivoli is still unknown?
google > zaphaudio
For info on the Tangband W871's in br enclosure.
Zaph/John also has a newer favorite in that size range
with enclosures designed.
There's lots on the small TB's but after a variety of
tests on my own, I've only heard them right on
open baffle.
When put in a desktop size enclosure, they always
sound boxy and pretty much nowhere.
Here at DIY audio there was thread on using TB's
2 per enclosure with a tweeter facing upward and
a ported box. This looked to me like a
workable solution for a desktop style small
enclosure maybe mounted on lightweight stands which
would open up the sound.
Lastly, the earliest research I did on the TB's was
from _audioXpress_/_Speakerbuilder_ magazine in which
the TB's were installed in very small enclosures with
open backs. I never built those but all the enclosures
shown were quite small as well.
A TB designed with the "Bose effect" just crossed my mind
but I'd have to look it up. It was a VTL design meaning
a small cabinet with a folded line length.
Old 7th February 2007, 09:54 AM   #5
Hi All,
I wonder anyone one has try to rebuild a box for the driver in the Tivoli Two. I realy like this tiny driver, and still don't know if they were made by Tivoli!!
Best regards,
CHOW
Old 7th February 2007, 06:08 PM   #6
gpapag is offline gpapag  Greece
gpapag's Avatar
Hi all
I had the Tivoli at the bed side table very close to my ears listening at very low level and I had observed that the middles were “dirty” and the bass excessive and boomy.
When listening from a distance and at higher level, these problems were not obvious (in fact boomy bass is an attribute that “sells” on this size of radios)
I opened it up, treated the cone with a dilluted plasticizer (two coatings), filled the internal volume of the box (not around the x-former) with fiberglass and stuffed the bass reflex tube with dacron.
Now, mids are much cleaner and bass not boomy but pronounced and tight.
Removing the protective screen from the front side of the speaker is another step forward.
George
Old 8th February 2007, 03:40 PM   #7
audiosteve's Avatar
I have both a Tivoli Model One and Boston Acoustics Receptor.
To my ears the Receptor is smoother sounding and has a more extended low end. If you want to reverse engineer something, I'd suggest targeting the Receptor instead of the Tivoli. In either case you can be sure that some type of EQ is also used. It is not just the box that accounts for the sound.
Old 9th February 2007, 06:20 AM   #8
gpapag's Avatar
Hi audiosteve
I was also quite sure that this is the case (judging from the amount of bass).
That's why I didn't bother running an impedance curve on the speaker-box combination and I applied the remedies in an experimental way instead.
George
Old 9th February 2007, 07:44 PM   #9
Dumbass is offline Dumbass  British Antarctic Territory
Tivoli says as much in their sales literature.
Old 9th February 2007, 07:58 PM   #10
celt is offline celt  United States
celt's Avatar
AFAIK, they are made by Foster/Fostex. At least, that's whats in my Model One.
drivers used in Tivoli Model one ? jives11 Full Range 10 24th January 2015 09:40 AM
Tivoli Pal battery problem gchrist Solid State 9 26th May 2013 07:06 AM
Chip amp to use with Tivoli speaker kenneth Chip Amps 4 17th February 2009 09:07 AM
Tuning LED a la Tivoli tubenut Analogue Source 2 8th December 2006 05:33 AM
Tivoli Model1 PSU hum fix / upgrade? jives11 Solid State 1 24th May 2004 08:30 AM
Copyright ©1999-2017 diyAudio
