How bad is really a crossover? - diyAudio
Old 27th March 2006, 12:20 PM   #1
Default How bad is really a crossover?
I am debating weather using an extended mid-range driver or a bigger low-mid crossed over to a high mid driver at 1000-2000. Using a bigger (10-12") low-mid driver has obvious advantages (power handling, compression, dynamics) at the price of the crossover.
Maybe someone has done the following experiment:
How about comparing the sound of 1) a full range 2) two of the same fullrangers with a cross over between them arond 1KHz. I`m sure someone with a digital xover has done it before. I would be happy to hear your comments.
regards,
seb
Old 27th March 2006, 04:39 PM   #2
Crossovers often are like your headline sentence; your meaning came across to the reader, just rather poorly.
(I don't mean this insultingly, I just thought it was a good analogy)
Old 27th March 2006, 06:11 PM   #3
jesper is offline jesper  Sweden
I have not done exactly that test, but I have tried crossing two fullrange driver, one smaller and one larger using a 1:st order filter. Due to the large overlap of the drivers the x-over hade true 1:st order acoustic slope. Not common with ordinary drivers. I also time aligned the drivers. The result was quite pleasing.
The sum of a true 1:st order filter is phase linear (if drivers are time aligned). The only difference against a single driver is loobing issues and of cause some passive components in the signal path.
/Jesper
Old 27th March 2006, 09:42 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: How bad is really a crossover?
regards,
seb
never use 800Hz - 2KHz region for xover point;
this is where your ears-brain combo is most sensitive;
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th March 2006, 10:10 PM   #5
AJinFLA is offline AJinFLA  United States
Banned
Hi choky. The Linkwitz Orion is xo'd @ 1.44k. In the middle of that range you mentioned. Perhaps you can describe its faults?
http://www.linkwitzlab.com/TAC-review.htm
http://www.linkwitzlab.com/Orion-TSS-review.pdf
Thanks.
cheers,
AJ
Old 27th March 2006, 10:20 PM   #6
Right, many very well regarded speakers cross over in the midrange. That`s why I posted the question on the first place. I thougt the 2 fullrange test would be quite conclusive on that point. Jespers experiment is very interestign, altough I would consider it better if one took the same FR driver for the highs and the lows. Very interesting anyway.
Old 28th March 2006, 12:25 AM   #7
Zen Mod's Avatar
Thanks.
cheers,
AJ
to each his own
anyway-OP mentioned two fullranges ;
using fullranges crossing it in most sensitive area of human hearing is waste of potentials
at least for me
Old 28th March 2006, 01:23 AM   #8
lndm is offline lndm  Australia
In my opinion, a well done fullrange is better than a mediocre crossover and a well done crossover is better than a mediocre full range system.
Perhaps full range would take more money and cabinet skills, and crossover would take more time.
Old 28th March 2006, 02:40 AM   #9
Banned
to each his own
at least for me
I see. Thanks for your answer.
Swak,
I guess the better question would be, if you are going to cross at 1-2k, why use a "fullrange" driver at all? That's tweeter territory.
Either use a small (3-5" fullrange with decent treble) driver and cross to a dedicated bass unit used below 150-300hz.
Or use a larger (8-10" extended range with decent bass) and cross high to a tweeter above 5k, etc. to avoid some of the inevitable breakup peaks/sound. Unless that's what you crave. I think that's why you sometimes see "helper" tweeters or "helper" woofers used with fullranges (I guess words like "crossover" and "2-way" are strictly taboo ).
cheers,
AJ
Old 28th March 2006, 10:16 AM   #10
This is a subject which I think have not been debated enough.
Iíve tried to list some parameters and compared between design variants. Feel free to comment and add/remove parameters.
What can we hear?
Uneven frequency response
Uneven phase response
Bad transient response (and low level ringing)
Tonal characters of different drivers
Passive components in signal path
Uneven reverbant field
Breakup modes
Limited power handling
How is most 2-ways (with x-over in the critical region) done?
+ Even frequency response
- 2:nd order (or higher) acoustic filter slopes -> uneven phase response
- Bad-ish transient response due to the above
- Large cone driver crossed to small dome or ribbon driver -> Tonal character difference
- Passive components in the signal path
- Uneven reverbant field
+ No or few breakup modes
+ Good power handling
How can a 2-way of fullrange drivers be done?
+ Even frequency response (if good drivers are used)
+ 1:nd order acoustic filter slopes -> even phase response
+ Good transient response due to above
+ Larger cone driver crossed to a smaller cone driver of preferable same material and structure -> Low tonal character difference
+ Few breakup modes
What about a single driver?
+ Even frequency response (good driver)
+ Even phase response (good driver)
+ No tonal differences
+ No (or very few) passive components
+ Even revarbant field (in the critical region)
- More breakup modes
- Lesser power handling
If the x-over is done right I would say we have a package with almost the qualities of a fullrage driver but with some other advantages. A matter of compromise of cause, but worth considering IMO.
/Jesper
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 05:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 02:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 10:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 06:48 AM
Copyright ©1999-2017 diyAudio
