Old 13th March 2006, 02:53 PM   #1
badman is offline badman  United States
badman's Avatar
Default FR125 with Passive radiator
Anyone seen this done? I've always preferred passive radiators to vents, and was thinking the little Seas 6.5" PR in a 16L cabinet with no added mass (tunes it to 50ish) would be just about right for the FR125, any thoughts?
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 13th March 2006, 03:06 PM   #2
Speakerholic
Cal Weldon's Avatar
I am a fan of PR's so I can't be objective. I say go for it. Just don't seal the cabinet permanent until you're sure about the weight issues with the drones. I assume you are using one FR per side?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 13th March 2006, 05:18 PM   #3
badman's Avatar
Yeah, was planning 1 FR and one PR per side. Was thinking upfiring PR. These would be desktop speakers for work.
Old 13th March 2006, 06:38 PM   #4
I like the idea, might work with the FR125. Do you know the Qts of Seas SP17R? Can't find it.
The cheap Dayton SD215-PR seems to do well also, might be worth a try.
Old 13th March 2006, 07:54 PM   #5
badman's Avatar
A passive radiator shouldn't have a Qts, Qts being a function of the mechanical and electrical characteristics, and as a passive radiator has no electrical or magnetic characteristics (unless you include the steel frame which is irrelevant here) it also has no Qts.
Old 13th March 2006, 09:15 PM   #6
Argh, I was trying to say Qms, which a passive radiator should have.
Old 14th March 2006, 06:27 PM   #7
Qms of the Seas PR's?
Old 14th March 2006, 06:49 PM   #8
badman's Avatar
I haven't seen it spec'd. Perhaps somebody else knows?
Old 14th March 2006, 07:27 PM   #9
knorke is offline knorke  Germany
knorke's Avatar
Done that with ood results....
Old 14th March 2006, 07:33 PM   #10
knorke's Avatar
ood = good ;--)
backside:
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
Passive Radiator For ESS qdoc Multi-Way 0 8th July 2004 05:06 AM
Copyright ©1999-2013 diyAudio
