I want my speaker in the corner but I'm wearing the dunce hat
Old 2nd February 2006, 11:36 AM   #1
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Question I want my speaker in the corner but I'm wearing the dunce hat
Moving in the very near future and will have to put my Tannoy Berkerleys (15inch Dual concentric) into the corners to get them in the room.
They are currently in the standard cabs but these boom when placed into the corner.
I may be able to enlarge the cabs slightly so thier sensitivity should rise. Am I right in thinking that a ported corner design will BOOM?
I was thinking that I may be able to enlarge the cabs and make them sealed (infinite bafle?) without loosing too much.
Some Tannoys used the corner for bass re enforcement.
Want to get building
If I'm not making noise, I'm making something to make noise
Old 2nd February 2006, 11:41 AM   #2
diyAudio Member RIP
if the dual porting is true, then be prepared to stuff one or both.
Can't see the point of enlarging the cabinets.
/sreten.
Old 2nd February 2006, 11:55 AM   #3
JRKO's Avatar
the ports are both on the front under the lower grille.
I will need to narrow the cabs and so will want to at least maintain the existing volume.
They will fit into the corners and the baffle will be angled across the room but not at 45 degrees.
Old 2nd February 2006, 12:12 PM   #4
On Hiatus
SY's Avatar
A ported cabinet will not boom in a corner if it's designed to go into a corner. There's nothing magic about ports. And where the ports are on the cabinet is not terribly relevant, given the long wavelengths. Increasing the box size will not increase the sensitivity.
Damping the ports might help a bit, but first I'd try to attack it more directly by lowering the box tuning. That will overdamp the bass, which will then get reinforced by the corner placement.
(edit: If memory serves, these were made before the popularization of T-S theory. It might be worthwhile to chuck the old cabinet design, measure the T-S parameters, and design a new box from scratch)
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd February 2006, 12:31 PM   #5
dnsey is offline dnsey  United Kingdom
If you have good woodworking skills, I'd seriously consider building replicas of Tannoy corner cabs - ideally GRFs. Avoid the really simple ones though, I think they were just devised to meed demand for corner enclosures without much thought for the sound.
I know the characteristics of the later drivers are a bit different from Golds, but the plans will only need minor modifications if any.
Old 2nd February 2006, 04:26 PM   #6
JRKO's Avatar
The GRF's would be nice but a tad big for the room.
Could I make a single sided version with it venting down the wall towards the listening position?
Forgive me but how would I go about measuring the T-S perameters?
One site has these:
RE: 5.2 Ohms
Fs: 14.7Hz
Qms: 6.25
Qes: 0.19
Qts: 0.19
L(1kHz):2.35mH
L(10kHz):1.35mH
Mms: 72g
Vas:830L
Sensitivity(2.83V/1m): 92Db
Old 6th February 2006, 12:58 PM   #7
Well, yes and no! You'd be designing an entirely different system.
http://sound.westhost.com/tsp.htm
Have a look around This tannoy group , you might find something that suits
I want my speaker in the corner but I'm wearing the dunce hatHide this!Advertise here!
vent by the speaker wall, or in a corner jmiyake Subwoofers 3 19th September 2006 11:57 PM
sub for corner placement... wuffer Subwoofers 5 23rd December 2005 09:23 AM
8-12" Bass reflex Full range Corner speaker (mono) Howismydriving Full Range 2 23rd October 2005 07:50 AM
Klipschorn corner horn speaker plans betection Multi-Way 3 29th November 2003 07:00 PM
out of the corner.... ChesterFuzzin' Multi-Way 6 6th June 2002 09:13 PM
Copyright ©1999-2017 diyAudio
