Old 30th January 2006, 08:16 AM   #1
Default Need help with speaker using 3 Hi-Vi B3S's
It's a long story, but for purely cosmetic purposes I need to make a few speakers, each using 3 HiVi B3S drivers, and nothing else. Anybody have any good suggestions on how I can make that work and sound good? I obviously only want to run one of them all the way to the top octave, but I'm not as experienced with more complicated crossover systems.
Old 30th January 2006, 08:32 AM   #2
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I tried it... didn't work very well because the midbass is very distorted and bass is nonexistant. But pass 300hz it is an amazing driver, especially for the price. Consider it a midtweeter rather than a fullranger.
Old 30th January 2006, 04:25 PM   #3
Actually, I forgot to mention that I will be using them in a home theater setup with a subwoofer, with an active crossover probably set at 120hz, just to keep them out of that troublesome reigon.
Old 30th January 2006, 04:27 PM   #4
Did you use any filtering when you did it, like the notch filters that Zaphaudio recommends, or just straight?
Old 30th January 2006, 04:29 PM   #5
OK, that will work. I thought you didn't have a sub
Old 30th January 2006, 05:05 PM   #6
the easiest way to use 3 drivers is to implement baffle
step compensation and crossover at the same time.
Two drivers in parallel are +6dB compared to one driver,
so use a simple 1st order series c/o, the frequency being
determined by baffle width.
so two drivers || for mid bass, one driver for mid & treble.
You'll also need the 8K notch filter for the mid/treble driver.
/sreten.
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
Mounting speaker. Speaker gasket? Cal Weldon Multi-Way 0 11th April 2007 10:36 PM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
Pi Speaker Reviews/or Similar Speaker G4ME Multi-Way 4 17th June 2003 12:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
