Old 12th January 2006, 04:23 PM   #1
bigwill is offline bigwill  United Kingdom
General Nuisance
Default 1uf or 2uf for helper tweeter
I have some drivers that go up to about 15Khz and need a bit of help above that. A lot of people say use a 1uf cap to cross at 10Khz (for 8 ohms) but the calculations say a 1uf cap puts the xover freq at 20Khz, but 2uf is 10Khz. Should I use 1uf or 2uf for a helper tweeter? I have a lot of 1uf metal film caps, will these work? Thanks
Old 12th January 2006, 04:38 PM   #2
Default Re: 1uf or 2uf for helper tweeter
Yes they will, so try one or two with the helper tweeter.
/sreten.
Old 12th January 2006, 05:40 PM   #3
General Nuisance
Done
WOW, what a difference!!!!
Old 12th January 2006, 06:15 PM   #4
General Nuisance
This is the first time the entire spectrum of my system is covered by DIY speakers! This cheapy mess of drivers sounds better than my mordant shorts running > 80Hz did!
I don't understand why the treble sounds so much better than on my supposed "hi-fi" speakers. Cymbals now sound like bits of metal instead of a generic TSSSss sounds. Very odd. The tweeters cost about 5 pounds each!
Old 12th January 2006, 06:22 PM   #5
Godzilla's Avatar
1uf provides -6db at about 20k.
http://www.zillaspeak.com/Crossover.asp
This means it's gradually blending into the full ranger you have. Sometimes you might want to use an L-pad to further adjust the volume of the tweeter for an even better match if needed.
I love super tweeters. The cheaper the better!
Godzilla
Old 12th January 2006, 06:35 PM   #6
General Nuisance
It seems to blend pretty well. The level is about right luckily since it roughly matches the full ranger's efficiency. Hopefully there isn't too much of a hole in the trebel response.
Old 12th January 2006, 06:50 PM   #7
zobsky is offline zobsky  India
zobsky's Avatar
congratulations!, TL subwoofer + widerange + helper tweeter is a good way to go.
you might be surprised at how cheap the components in many "hi-fi" speakers really are (and also how compromised commercial designs often are), hence the whole diyaudio thing
be sure to check that your tweeters aren't running several dB louder than the rest of your system (and in general that your system has a balanced response. there are several shareware RTA audio analysis programs out there
"Any fool can know. The point is to understand" - Albert Einstein
Old 12th January 2006, 06:56 PM   #8
May I ask what driver are you using?
Old 12th January 2006, 07:04 PM   #9
General Nuisance
Is it possible for this to happen and go unoticed? I don't want to be blasting my ears with loud 20Khz all the time! I'm 18 so my earing still goes that high and I don't want to mess it up with some badly integrated tweeters I have a bad feeling they're too loud actually... turning the treble down on my preamp gets rid of the treble quite a lot - but it's not completely gone like on my other speakers. The treble set to +0 sounds good, possibly rather bright.
Old 12th January 2006, 07:16 PM   #10
zobsky's Avatar
even if your hearing goes out to 20KHz, chances are it's not going to be as sensitive at that frequency as say, 1000Hz.
if you have the T/S specs for the drivers, you could compare the efficiency of the widerange and the tweeter to guestimate if you might have a mismatch.
from there, experiment, ... a small resistor is a simple way to pad down the output ot a driver, if needed. google up for more info
B20 plus cheap helper tweeter - why? Godzilla Full Range 6 4th October 2007 03:22 PM
Lowther DX4 ,helper tweeter limono Full Range 0 6th March 2007 04:42 AM
Active Crossover for helper tweeter Zero One Full Range 8 18th June 2006 07:52 PM
Ideal 'helper' tweeter Nuuk Multi-Way 67 9th March 2006 12:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
