Is there anything higher than 8 Ohm speakers? - Page 2 - diyAudio
Old 8th January 2006, 08:01 PM   #11
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Douglas Self shows in his "Power Amplifier Handbook" that for a typical bipolar transistor power amplifier, distortion driving a 4 Ohm load is higher than driving an 8 Ohm load. Using his argument, a 16 Ohm load would further reduce distortion (it's all about current). However, transistor amplifiers are voltage sources, so if a loudspeaker manufacturer makes their loudspeaker 4 Ohm rather than 8 Ohm they gain 3dB of apparent sensitivity. That's why most modern loudspeakers are 4 Ohm. Conversely, the 11 Ohm LS3/5a loses out even further...
If we used 16 Ohm loudspeakers, we could get away with thinner loudspeaker cables.
As previously mentioned, valve OTLs have a heart attack when faced with loads < 16 Ohm.
Valve amplifiers with output transformers don't really mind whether it's 4 Ohm, 8 Ohm or 16 Ohm (provided their output transformer can be configured correctly).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th January 2006, 06:55 AM   #12
rjb is offline rjb  New Zealand
Scottmoose
That figure you quote for a Phillips speaker is not far out from memory. They called it Hi-Z, made a number of different driver sizes, and used it in mains transformerless valved amplifiers and TV's. Lethal items that would kill any unwary serviceman. Valve filaments were in series, and the mains directly rectified. The chassis had to be totally insulated to protect users, but this was poorly done, and any cabinet damage could turn them into a death trap.
Old 9th January 2006, 08:44 AM   #13
Scottmoose's Avatar
Shocking...
I bet the required number of windings in the driver made them nice and reliable too...
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 9th January 2006, 10:25 AM   #14
Most modern speakers are 8 ohm, 4 ohm are pretty rare (although continental manufacturers tended to use 4 ohms), except for in-car speakers where you have a lack of voltage and 4 ohm is the norm.
Historically, in the valve days, most speakers were 16 ohm.
Nigel Goodwin
Old 9th January 2006, 11:19 AM   #15
Depending on the manufacturer they can be 4 ohm, 6 ohm, or 8 ohm for home usage products. Most common.
Commercial applications can be 8 or 16 ohm as it is common to have either 8 or 16 ohm diaphrams for high frequency horns or a choice of 8 or 16 ohm low frequency drivers.
Old 9th January 2006, 02:06 PM   #16
jeremym is offline jeremym  Canada
The drivers in my TV are marked 32 ohms, I was surprised by this.
Old 9th January 2006, 02:27 PM   #17
I see the occasional 64 ohm speakers in TV's as well.
Nigel Goodwin
Higher power A75. dinu Pass Labs 76 15th January 2008 06:23 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
higher voltage PS Steven Koay Chip Amps 5 10th September 2003 11:29 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Copyright 1999-2017 diyAudio
