my Hedlund horn with FE208ESigma - Page 5 - diyAudio
Old 28th August 2012, 02:24 AM   #41
Originally Posted by Scottmoose View Post
A mass loaded horn? You'll get more LF extension & a flatter alignment at the price of greater cone deflection an octave above Fb.
Yes to that as long as the cone deflection does not exceed Xmech at normal listening levels.
Sam
Old 28th August 2012, 10:55 AM   #42
Scottmoose's Avatar
Xmech is the mechanical limit of travel, either by limitation of suspension, or when the VC belts into the back plate. If you exceed it, you've broken the driver.
Old 28th August 2012, 04:03 PM   #43
I agree Scott, I mentioned Xmech because you said that below Fb, cone deflection will be more; so I assumed that the 1.6mm Xmax rating of the 168Sigmas will anyway be exceeded.
Sam
Help required for a Fostex FE208ESigma project lsfarzo Multi-Way 7 8th December 2007 10:18 AM
Hedlund Horn / Coaxial ?? jcmjrt Multi-Way 0 29th December 2006 10:31 PM
DIY Hedlund Horn vangogh-hk Multi-Way 5 24th March 2006 05:12 PM
Hedlund horn plans Michael Speaker Full Range 3 17th November 2005 12:23 PM
Hedlund Horn using tad 1602 kartsmart Multi-Way 0 12th June 2005 11:50 AM
Copyright 1999-2017 diyAudio
