2x fullrange in parallel - Page 4 - diyAudio
Old 16th June 2006, 07:05 AM   #31
Scottmoose's Avatar
The Zu's were measured by HiFi + magazine this month at 95db 1w/1m. Methinks they're being a little selective in where they get that 101db efficiency rating. It might be at one particular point in the frequency range. One very small, particular point. But that's it.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 16th June 2006, 10:14 AM   #32
Refering to the original question, this one here is using two fullrangers in push-push configuration in an active speaker:
http://www.voice-point.com/
Charles
Old 18th June 2006, 11:31 AM   #33
lepain is offline lepain  Netherlands
Send a message via MSN to lepain
Dont use two fullrange drivers in normal configuration. You will never get the drivers close enough to avoid lobbing at mid, and high frequencies.
Old 18th June 2006, 01:36 PM   #34
phase_accurate,
The speaker system in the link you just posted does NOT show two fullrangers in use. It shows a 1.5 system in which the back driver only operates in lower frequencies (less than 300-400 hz?). Because the rear driver is not operating full range lobing problems are avoided. So, the advice is still relevant. Do not use two drivers full range, you can't get them close enough to avoid lobing......
Old 19th June 2006, 06:51 AM   #35
Sorry 'bout that. I knew that but forgot to mention. I wanted to show a way of cleverly using two identical drivers but completely failed to mention this detail !
Charles
mostly fullrange tomtt Full Range 1 25th April 2006 12:04 PM
Fullrange for me? bjackson Full Range 13 31st August 2005 09:55 PM
parallel/series line arrays with fullrange? NullPointerAlex Full Range 4 29th December 2004 08:17 AM
fullrange or 2.5 way?? AudioGeek Full Range 2 18th August 2004 07:26 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Copyright 1999-2017 diyAudio
