CSS FR125 open baffle test (2mb film)
Old 19th December 2005, 04:16 PM   #11
MCH is offline MCH
I've built these in the miniOnken box. They are very good sounding. I like them very much, but I would not use them without a subwoofer. With my Tempest they sound wonderful in my setup.
In my experience I find most speakers can do with a good subwoofer. There is bass and then there is........ bass.
Old 19th December 2005, 04:21 PM   #12
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
that's sounds really good, what's the sensitivity of those speakers?
80dB.
I'm going to try them with my Prometheus subs somewhere in January 2006.....first need to build my subs
If you can see the speaker cone move...it's not hifi.
Old 19th December 2005, 05:42 PM   #13
Landroval is offline Landroval  Finland
Originally posted by Bas Horneman
80dB.
Is this because it's a dipole or how does these thing work?
Old 19th December 2005, 06:09 PM   #14
That is the sensitivity of the driver I think. But the implementation does change the efficiency a little...methinks.
It depends how you measure it. Hobby Hifi says 80dB, Klang und Ton says look at the frequency graphs (where you can see most of the time it is indeed close to 80dB except for between 100 and 300 Hertz where it goes to about max 85dB)
Old 19th December 2005, 07:37 PM   #15
bigwill is offline bigwill  United Kingdom
80dB.
Despite this, do they still go loud with just 8W of power? I keep imagining speakers with sensitivies that low needing the volume turned all the way up!
Old 19th December 2005, 08:29 PM   #16
Actually my version of the Ladyday is closer to closer to 6 watts then 8 watts.
Yes it goes that loud ..but it's a small little room. However according to Dave Dlugos it does indeed not respond well to little SE amps. On the other hand though I was suprised that a 50watt gainclone did not go all that much louder than my 4 watt SE amp.
Old 19th December 2005, 10:12 PM   #17
TomekZ is offline TomekZ  United States
I too am listening to the CSS FR125S in open baffles. First for a few weeks with a 20 watt/ch, then a 40 watt/ch gainclone and Channel Islands VMB-1 chip amp, then a Sonic Impact 8 watt/ch, then a Wright Sound 3.5 2a3 SET. Between the 40 watt chip amp and the 2a3 (3.5 watt/ch) SET, the potential gain was about the same (except the sonic impact was weakest). I just do not have any bigger amps around. These days I most like the Wright Sound with the FR125S open baffled.
This setup also in a small room.
Old 19th December 2005, 10:46 PM   #18
Unreal isn't it :-)
Old 20th December 2005, 04:09 AM   #19
Raj1 is offline Raj1  United Kingdom
I think that most of us don't really push speakers past 80db for normal listening anyway. I don't like music too loud and probably don't use more than a watt or so of power.
raja
Old 29th March 2006, 04:47 PM   #20
croat47 is offline croat47  United States
croat47's Avatar
Default 2.0 Dipole?
Following on the OB/BR thread:
What about two in an OB?
CSS FR125 open baffle test (2mb film)Hide this!Advertise here!
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
Open baffle driver eyeball test ozziozzi Full Range 5 8th November 2006 12:48 AM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
