New version of Martin King's MathCad Worksheets is coming soon!
Old 15th December 2005, 06:31 PM   #21
jeremym is offline jeremym  Canada
This is very exciting news! I was under the impression that MJK was not willing to release any new software because of intellectual property issues (understandable). I can't wait to play with it-this should prove to be an exceptionally powerful design tool. Thanks Martin!
<damn....this means I am going to have to build *more* speakers.....where will I put them???? When will the madness end?>
Old 15th December 2005, 10:19 PM   #22
SCD is offline SCD  Canada
Default too many speakers
I am with you on that one jeremym.
I really like the work MJK has done and am keen to send in what ever token amout he feels in reasonable. The work he has done has made me a very true believer in TL designs.
Good for you Martin and thank you very much.
My suggestions have already been expressed bipole, bipole, bipole, bottom exit ports.
SCD
Old 15th December 2005, 10:25 PM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Scottmoose
(At this point, I will mention that I'm always a little uneasy about using ports narrower than 3", as I wonder about port-noise. However, other people have sucessfully used them, and this has done the trick as far as the predicted response goes.)
Brings up the sunject of flared ports...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th December 2005, 11:19 PM   #24
frugal-phile(tm)
planet10's Avatar
and while requests are being considered, 1/4 space rear mouth horns...
dave
Old 15th December 2005, 11:46 PM   #25
Tweeker is offline Tweeker  United States
Do these sheets cover top firing cabs like Terry Cain's BIB TQWT?
Or is it same issues as bottom ports?
Be sure your foil hat has a good low impedance ground.
Old 16th December 2005, 12:05 AM   #26
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Thanks, Martin & scottmoose
I'm working on a simulation of a ML TQWT with the sides being trapezoidal.
I think this is OK (Y/N)?
This also raises the question:
What about sloped baffles? I see the feature for toe-in. I hope I didn't overlook that one. My current application is to "aim" the driver's CL's towards the ear, not to compensate for acoustic centers.
What about height of baffle above floor? Such as for the Totem-style or others on spikes?
I, like scottmoose have combined parameters for 2 drivers to be modelled as one. Is this (an mtm) a valid execise in a ML TQWT?
I would like to ask the location for the "best value" (OK, I'm tight...) for the purchase of Mathcad.
Martin, name your price for your worksheets.
For those like myself who still work with Explorer, I copy and paste parameters and response graph into a 2 X 5 table in a Word.doc. This lets me compare one above the next to judge what progress I make in the simulations. It saves paper and pushing it around until a design matures.
Thanks again
Old 16th December 2005, 12:42 AM   #27
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yes. Far as I'm aware. I've never had any problems at least. I paste into Word etc too -I'm scouring ebay for a genuine copy of a late version of MathCad that I can afford too -time I had one.
Dave -good point about flared ports. Not something I've ever used, believe it or not, but could be worth looking into.
No, they don't as yet cover upward-firing enclosures like Terry's BIB box as yet. Similar issues to downward firing ports I believe, though probably easier to resolve as there's less variables to consider. I'm sure Martin can do it though. Regarding Terry's BIB enclosure, it has other issues in modelling I believe, owing to its interaction with the room -it's closer to being a horn in this respect than other ported designs. (I'm still a fan of it though, even if it's the one enclosure type I still have to create using a rule of thumb).
Best
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 16th December 2005, 12:58 AM   #28
frugal-phile(tm)
planet10's Avatar
I have a ton of heavily flared elliptical ports i'd love to give away instead of turning into plastic 2x4s.
dave
Old 16th December 2005, 01:34 AM   #29
Jorge is offline Jorge  Brazil
Default MTM
I've built two MTM boxes (a photo of the newer one is in MJK's gallery). One was a conventional TL, the newer is a MLTL.
Both drivers measured equal in close miking up to the cuttof frequency, from there on they started to diverge.
This doesn't means that the equivalent driver placed in the mid point between the real ones is the ideal - just that it's quite acceptable.
Old 16th December 2005, 01:48 AM   #30
ScottG is offline ScottG  United States
awesome!!!
how about anti-phase floor effects (..floor bounce, Allison Effect, etc.)?
(these can often alter BSC curves quite a bit at the top of its range)
perspective is everything
New version of Martin King's MathCad Worksheets is coming soon!Hide this!Advertise here!
mathcad worksheets brsanko Full Range 0 15th March 2009 08:53 PM
Question on MJK's mathcad worksheets cs Multi-Way 3 3rd November 2006 06:24 PM
New versions of Martin King's MathCad worksheets Scottmoose Multi-Way 0 14th December 2005 11:05 PM
