New version of Martin King's MathCad Worksheets is coming soon!
Old 23rd March 2006, 08:12 PM   #211
lovechild is offline lovechild  Europe
Hello,
is it possible to simulate aperiodic cabinets with the worksheets now available?
thanks, martin
Old 24th March 2006, 02:04 AM   #212
MJK is offline MJK  United States
Hello Bostjan,
Thanks for the positive feedback.
Is there a posibility to simulate JENSEN TRANSFLEX enclosure with combination of several worksheets. I've tried this with offset driver WS but I don't know if I understand adding and substracting dbs very well.
To be honest, I do not know what a JENSEN TRANSFLEX enclosure looks like, based on the name alone it sounds complicated. If you have a picture or drawing I might be able to provide a few hints, if you post it here I am sure others might also chime in. You probably should start a new thread.
Sorry for my English
No apologies needed, your English is just fine.
(I think much faster than I am able to type in English)
Me to.
Old 24th March 2006, 02:10 AM   #213
Hi lovechild,
You probably can simulate an aperiodic enclosure in MathCad. My guess would be to use a port length equal to the wall thinkness of the enclosure and specify 1 lb/ft^3 of fiber stuffing. You can't go higher then 1 lb/ft^3 or the curve fit goes unstable and your results will get really weird. Then you would need to vary the diameter of the port until you achieve an aperiodic response typical of whatever venting arrangement you are using. The port diameter would have no physical relationship with the real vent size and is kind of an answer after the fact. But I think that this would work and maybe you could apply what you learn to other designs using the same damped vent arrangement.
Old 24th March 2006, 08:42 AM   #214
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally posted by MJK
Hi lovechild,
What if the port is not round but rather a long rectangle like one of the Thiel CS1.6 speakers, is there any way to simulate that? Can you simulate an enclosure with two ports?
Hear the real thing!
Old 24th March 2006, 11:43 AM   #215
Not at this time in Ported Box. The closest you can get would be to edit TL Sections and attempt to model the geometry, TL Sections has a rectangular opening.
I don't have any worksheets with dual ports.
Old 24th March 2006, 12:51 PM   #216
Martin, thanks for explaining!
regarding the rectangular openening I once had copied a post in another forum, I unfortunately I can't find the link anymore. That's what was said:
If you want to model aperiodic enclosures, his worksheets are EXCELLENT for that effort.
If you have a highly tapered TL, 12:1 for example, and stuff it, you will have an aperiodic enclosure more than a TL. His worksheets also accomodate stuffed, vented enclosures as well.
Old 26th March 2006, 08:40 PM   #217
e-star is offline e-star  Slovenia
Default jensen transflex
Jensen Transflex is a transmision line enclosure but the driver is enclosed in a enclosure. I will start a new thread in a subwoofer forum if there is any posibility to simulate this enclosure with worsheets. Here is a picture.
Cheers
Bostjan Skok
Old 26th March 2006, 09:47 PM   #218
GM is offline GM  United States
GM's Avatar
Greets!
I bet Tom Danley wouldn't be too pleased to see it made public.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th March 2006, 10:37 PM   #219
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
At this rate we'll be trying to sim those madcap JBL Aquarius things from the early 1970s.
Now, there's an idea...
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 26th March 2006, 11:03 PM   #220
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
New version of Martin King's MathCad Worksheets is coming soon!Hide this!Advertise here!
mathcad worksheets brsanko Full Range 0 15th March 2009 08:53 PM
Question on MJK's mathcad worksheets cs Multi-Way 3 3rd November 2006 06:24 PM
New versions of Martin King's MathCad worksheets Scottmoose Multi-Way 0 14th December 2005 11:05 PM
Copyright ©1999-2017 diyAudio
