Advice on highest quality full range driver
Old 11th December 2005, 09:33 PM   #11
deandob is offline deandob  Australia
Thanks all,
Nelson's First Watt site has a good write up on the driver comparison.
Dean
Old 11th December 2005, 11:00 PM   #12
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Sorry Dean -it might have helped if I'd actually remembered to post the link! I see you found it in the end though!
Cheers
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 12th December 2005, 02:54 AM   #13
From what I can work out after researching this for a while, for the smaller drivers the ranking for low distortion and decent treble:
1) Lowther DX55
2) Veravox 5X
3) Jordan jx92
The fostex range look good, but not quite in the class of the above drivers.
Next step is to study the enclosures, datasheets and costs to decide on a 4" - 6" driver that can be used for near field listening.
I have not been able to find much on the Veravox 5X, can anyone provide further pointers or experience with this driver?
Dean
Old 12th December 2005, 08:14 AM   #14
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Hi Dean,
I know that there has been a write-up about veravox 5X in one of the german diy magazines (with measurements, etc...) If you do a search for voravox 5x here, I'm sure you can find some folks who have scanned those pages, so they can send them to you...
Best of luck Martin
Old 12th December 2005, 08:48 AM   #15
soongsc is offline soongsc  Taiwan
soongsc's Avatar
1) Lowther DX55
2) Veravox 5X
3) Jordan jx92
Dean
Have you compared the Xmax of these drivers? The amount of volume the drivers can push is very critical for bass punch.
Hear the real thing!
Old 12th December 2005, 09:12 AM   #16
Scottmoose's Avatar
True. Depends what enclosure you want to put them in too of course. For the moment, Nelson Pass' (again!) J-Lo looks to be one of the better DIY bets... providing you can get them through the door and have an understanding Other Half of course...
A monster TQWT like Terry Cain's Bigger Is Better box could also be viable, providing you've got the corners or a rear wall to load it. Although you aren't intending to go lower than 100Hz, you say your room is pretty big, and you want to rock, so this is one case I don't think an MLTL will be appropriate (and from an MLTL-nut like me, that's really saying something) as you'll want to be shifting as much air as possible.
Don't ignore the Lowther's cheaper PM45 and PM55 either. I haven't heard any comments about them, but they look good to me.
Best
Scott
Old 12th December 2005, 09:23 AM   #17
Soongsc.
I agree. The Xmax comparisons are as follows:
DX55: +- 1mm. Wow this is small. Not going to move much air with this excursion.
5X: +- 1mm also. Looks like the 5x uses a similar design philosophy to the DX55.
jx92s: +-4.5mm. This driver will move a lot more air. I wonder if it will sound as dynamic/fast as the other 2, given their lightweight approach to cones which limits the Xmax.
Scott, as I want to build a more compact speaker (monitor), it looks like the Jordan will provide better bass in a smaller box compared to the other two and has a much lower Fo.
Dean
Old 12th December 2005, 10:11 AM   #18
soongsc's Avatar
Soongsc.
Dean
I'm not familiar with the DX55 and 5X, but if they have a larger cone area, that also needs to be taken into consideration. Some drivers spec their Xmax more conservatively and degrade gradually beyond Xmax. That's why I wish manufacturers could publish more large signal test data instead of just the traditional T/S parameters. The Klippel site provides some good insight in this aspect.
Old 12th December 2005, 10:50 AM   #19
lithoc is offline lithoc  Malaysia
lithoc's Avatar
Visaton B200 does sound fantastic to my ear very pronounce vocal
http://www.visaton.com/english/artikel/art_771_1_3.html
Old 12th December 2005, 11:06 AM   #20
hi,
here: http://www.diyaudio.com/forums/showt...ht=#post652252
you can find "almost" direct comparison between JX92S and 5X....
Martin
Advice on highest quality full range driverHide this!Advertise here!
Vintage Full range- Need some cab advice waam68 Full Range 7 19th August 2008 10:30 PM
Full range vs. quality studio monitors schn0354 Full Range 28 17th August 2008 05:12 AM
Full Range Dipole Designs - Any Advice? Forster Full Range 5 9th January 2007 02:13 PM
Advice: a fence post for a full range? sol Full Range 25 1st January 2007 11:26 PM
Advice on full range enclosure for 5.1 setup CDJ Multi-Way 3 21st January 2003 06:28 AM
Copyright ©1999-2017 diyAudio
