#31 |
Monster horns seem to rely on some resonance to achieve the low end, wouldn't that make the low end ring longer? That would really effect the "Punch quality" wouldn't it?
With the same air volume, I think the larger cone would perform better than a smaller cone in terms of punch capability.
Hear the real thing! |
#32 |
8 hours sleep overnight and I come back to a page full of replies - especially when a few of the posters are in my time zone!
The new Jordan JX53 do sound interesting, although my ISD model of the preliminary specs dont show it doing as well down low compared to the old model (probably a mistake in the data). The old model has a reputation of burning out if overdriven, so hopefully the new model will be better in this regard, and using an active highpass filter will help. The B200 is a little too big for my needs, but if a 8" paper speaker can do a good job reproducing the treble it is indeed a marvel. Regarding subs, as I'm listening near field, if I cross over around 100Hz and have the bass unit very close nearby I dont have a problem with any slight directonality in the bass. Also with near field I dont need such high SPLs. Bandor dont get the same rave reviews as the Jordans and it seems the Jordans have had ongoing development/tweaking. The Hartley sure is a monster, but can't find any data about them. Regards, Dean |
#33 |
Interesting thread. It's nice to read about options beyond some of the usual suspects. I have to say that the Veravox looks really intriguing to me. Could be the next on my list.
With regards to the JX53, the current version. I read that it's not recommended to cross it much below 500hz. While it seems you could get away with it, I guess it doesn't have much body at in the upper bass / lower mids area. Just thought I'd share. I'll be curious to hear what everyone thinks of the new JX53. Good luck with your search. |
#34 |
I think the JX92S would be an excellent choice, but I always feel that if you are willing to part with much dosh, you ought to actually listen to a pair before buying.
The new JX6 allegedly has an octave-lower resonance than the JX53 and could theoretically reach 100Hz, so don't rule it out either. |
#35 | |
I do agree with you that 2.1 is a very good setup. Initially I thought you were asking for single driver fullrange. 8" fullrange speaker at high frequency(>10khz) usually are very directional. IMHO, I prefer <4" mid/high & >8" woofer for 2.1 setup. crossover at 100hz. |
#36 |
lithoc,
Yes, a <4" driver with a 8" or larger sub at 100Hz looks to be the best setup for near field. The new Jordan JX6 would be worth hanging out for, especially if it does go lower by an octave (even if my preliminary WinISD model says it wont). I currently use a 2.1 active highpass filter for a set of TangBand monitors with a lowpass Linkwitz transform for a small sub and get excellent results. Using this approach with the new Jordan should raise the performance bar even higher. Dumbass, agreed, it would be good to listen before parting with the cash. I'm looking forward to initial reports. One1speed, if you can dig up more info on the veravox or listening impressions, please post. Regards, Dean |
#37 | |
With my experience with Jordan drivers, the later versions are always better than the earlier ones. If the cone area is increased, then it will have better low frequency driving capability. Got our fingers crossed.
#38 |
Bandors don't get the same rave reviews? True. Doesn't make them bad drivers though. They all come from the same person as I understand it. You see, the good lady who owns Bandor is, I believe, Ted Jordan's ex-wife, and the Bandor drivers are I suspect based upon some of his earlier designs which went with the divorce settlement. I hasten to add that I don't know that for certain, and anyone who knows better do correct me if I'm wrong.
As for larger cones performing better than smaller in the same air volume -sort of. Again, depends on the circumstances, and how the enclosure has been optimised. Assuming properly engineered and optimised enclosures (and drivers), I agree that the larger driver will tend to have more punch in the bass than a smaller one as it can shift more air. I think the DX55 etc strike a pretty good compromise. Big horns relying on some resonance? Probably, I'm no expert on horns, so I'll leave better qualified people to comment on that and stick to my TL variations for the moment. That said, 99% of BLHs are actually QW loaded, not horn loaded at bass freqencies, and the smaller you go, the greater and higher up the QW loading tends to be. The Buschorn is a classic example -if you look at the measured response and frequency curves, it screams quarter wave loading -there's hardly the slightest hint of horn loading at all. I would tend to classify that as more of a resonance issue than that seen in larger enclosures, like the J-Lo for example. Then again, I'm just conjecturing here. 8" drivers can indeed do decent high treble -but it'll cost you. Lowther DX4 for example, or higher. The cheaper 8" units like the Fostex range and the cheaper Lowthers make a very good fist of it indeed, but if you're after treble quality as good as a high-end tweeter, you have to pay a whole lot more, or downsize to a slightly smaller driver like the DX55, a Fostex 6 1/2" unit etc. Best Scott |
#39 | |
Ref the Bandors, when I last heard several Bandor systems in the late 90s at a trade show, I thought the Jordans had the edge and they've probably been subject to more continuous development since. The JX53 got up to mk3 and the 6 is supposed to be a significantly better driver. |
#40 | |
| Vintage Full range- Need some cab advice | waam68 | Full Range | 7 | 19th August 2008 10:30 PM |
| Full range vs. quality studio monitors | schn0354 | Full Range | 28 | 17th August 2008 05:12 AM |
| Full Range Dipole Designs - Any Advice? | Forster | Full Range | 5 | 9th January 2007 02:13 PM |
| Advice: a fence post for a full range? | sol | Full Range | 25 | 1st January 2007 11:26 PM |
| Advice on full range enclosure for 5.1 setup | CDJ | Multi-Way | 3 | 21st January 2003 06:28 AM |
| Page generated in 0.14457 seconds (81.31% PHP - 18.69% MySQL) with 11 queries |
