full range without filtres
Old 15th December 2005, 06:39 AM   #41
Artmaster is offline Artmaster  Ukraine
Artmaster's Avatar
gday!
ok. I'm agree about familydoctor.org material. but I think - it's usual doctor's afraid.
unfortunatly http://www.fostexinternational.com/d...F-Series.shtml show me PDF for ff125K instead of FF225. pity, but I find Xmass = 0.15mm there.
for F200A it's=2mm at least. I'm not understand, how they to take it?!
Xmax - Maximum peak linear excursion of driver. so, how i's loud for 100 Hz as well??? it's means some ... more excursion. even to 1 way.
like I know you have experience for Fostex driver use.
would you explane me about directional radiation pattern of these driver?
I have an idea about it.
thank you.
Artmaster live in https://www.youtube.com/Depo196
Old 15th December 2005, 11:17 AM   #42
gamma is offline gamma  Sweden
I found the datasheet for FF225
http://www.fostexinternational.com/d...pdf/ff225k.pdf
Old 15th December 2005, 11:36 AM   #43
Artmaster's Avatar
thank you. it's enough. now I'm thinking about 'fullrange drivers and narrow diagram" based on these drivers
Old 16th December 2005, 10:47 AM   #44
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Originally posted by Scottmoose
One idea I'm kicking around is loading a pair of these in an enlarged version of Terry Cain's Bigger Is Better TQWT.... I'm curently thinking of external dimensions along these lines: 70" tall, with the driver at 39" from the base, like the originals. 10" wide x 18" deep (external). Not small then, but I've seen larger cabinets too! Could be interesting...
OK, I wasn't stricktly speaking telling you everything here. At the time of the above, the cabinets, using the above drivers and dimensions were actually about 1/2 way through the build process (I was wary of mentioning that part, in case they didn't work -shades of irony that the subject of the frequently forgotten 225 should come up again right at the same time), and were completed shortly afterwards and installed in the home of their new owner. They still need to be painted and have the tweeter added -Simon's doing that himself under the eagle-eye of his good lady. But they work. Oh yes. As it happens, the 140" line length is probably about right for them in this enclosure anyway as I gathered from a search a minute ago that Nelson has measured their Fs as being a fair bit higher than Fostex say it is. Take his word for it any time. 30AWG magnet wire to the amp and you're in business.
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
full range without filtresHide this!Advertise here!
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
5.25 full range boxcustom Full Range 0 20th March 2007 09:33 PM
