fe167e enclosure?
fe167e enclosure?
Old 1st December 2005, 03:45 AM   #1
jwb009 is offline jwb009  United States
Default fe167e enclosure?
Looking to build my first set of speakers, and I've figured I'd go with the fe167e as the driver. Now, I really like the look of the JTM/2's from Carolina Audio. I'm curious as to how they setup the 3 folded TL design. Is there any diagrams available for this type of design?
Alternativey, could I simply make it a BR design, with only an empty box and single port?
Thanks for the help.
Old 1st December 2005, 02:09 PM   #2
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Smile 167e
http://www.zillaspeak.com/ZillaSpeak...tex168-167.asp
People have built both 15 and 21 L boxes with good results using the 167e.
Others have built some neat pipes.
Peace,
Godzilla
Old 1st December 2005, 07:01 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
fe167e enclosure?
Default Re: fe167e enclosure?
I'd recommend Bob Brines' ML-TL. Works really well with these (and looks like a BR in the sense that it is a box with a port)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st December 2005, 07:23 PM   #4
I'm assuming Bob Brines' version is this?:
http://www.geocities.com/rbrines1/im...sals/FE164.gif
If so, will it become a problem if I change the dimensions so it is much less deep and much wider, as in the Carolina Audio. I'm thinking the diagonal piece inside wouldn't work then, am I correct? Sorry for the questions, I'm new to all this. Thanks!
Old 1st December 2005, 07:30 PM   #5
doorman is offline doorman  Canada
doorman's Avatar
jwb009: The pic you've posted is not BB Ft 1600's, which is essentially a tube with a slot port at the bottom. What Dave said!
Old 1st December 2005, 07:36 PM   #6
frugal-phile(tm)
planet10's Avatar
fe167e enclosure?
I can't find the drawing he had up on his site.
45" internal height, driver down 11", with a 9" wide, 1.5" tall, 4.25" deep slot port at the bottom. Cross-section is 81 in^2.
He has detailed plans with all his tricks available for sale (FT1600)
dave
Old 1st December 2005, 11:09 PM   #7
Looks easy enough. So with a cross-section of 81 in^2, does it matter how you get those 81 inches, ie is 9x9 ideal, or will something like 5 x 16.5 work as well?
Question 2: What is the purpose of the 3 cross members in this picture? Is it simply for stability?
http://www.geocities.com/rbrines1/Pa...ard_Detail.jpg
Old 1st December 2005, 11:13 PM   #8
doorman's Avatar
The 3 "picture frames" you see, are bracing
Old 1st December 2005, 11:18 PM   #9
SCD is offline SCD  Canada
This is a tried and functional design.
Has any one tried anything else with this driver. I made the FT1600 and I love the sound and was thinking about a bipole or a bipole TQWP. I would love to see some discussion on that. It seems the CSS drivers are getting all the attention right now.
How about some discussion.
SCD
Old 2nd December 2005, 02:32 AM   #10
frugal-phile(tm)
planet10's Avatar
fe167e enclosure?
In theory a ratio of width to depth that is an irrational number is best. Say we take the golden ratio 1:1.618... then internal dimensions would be 7" x 11 5/8"...
Those are shelf bracing... IMO braces running up & down would be more effective (like in Scott's)
dave
fe167e enclosure?Hide this!Advertise here!
best enclosure for fe167e masterxela Full Range 7 16th August 2008 10:39 PM
Fe167e Br regal Full Range 19 31st August 2005 12:30 PM
recommended BSC for FE167E 15L BR? AudioGeek Full Range 6 16th March 2005 04:05 AM
what to do with FE167e's? AudioGeek Full Range 8 27th February 2005 07:16 PM
fe167e double br moleskin Full Range 1 20th August 2004 04:31 AM
