Old 8th November 2005, 12:39 PM   #1
wim is offline wim  Netherlands
Default Tangband W3-871S
Today i received 2 full range tangbands W3-871S and i am wondering how i can get the best out of them, I mean a DIY enclosure (with or witout aditional high or low drivers in it). I prefer to use the Tangbands alone, without additional drivers..
Anyone made somothing that is very good?
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn.
Old 8th November 2005, 01:02 PM   #2
kec is offline kec  United States
kec's Avatar
Wim,
I built Salas' TB3, but it requires 2 871's per side. The thread is here My ''TB3'' mini bipole plans
The bass is quite surprising for a small box.
You could also build Cyburg's Needles. It only requires one driver. I'm still playing around with this, but the initial results are quite good.
-Ken
Old 8th November 2005, 01:27 PM   #3
Thanks Ken, no problem to order another 2 drivers if the results are good with your design. I am going to read the thread you offered.
thanks for so far.
Old 8th November 2005, 01:56 PM   #4
gmilitano's Avatar
Default Re: Tangband W3-871S
Here are a couple of links to a full range monitor using the W3-871S.
http://www.vikash.info/audio/W3-871S
http://www.zaphaudio.com/archives.html
Good luck,
Gio.
Old 8th November 2005, 03:34 PM   #5
Thanks and thanks; wonderfull form!
Old 8th November 2005, 03:50 PM   #6
joensd is offline joensd  Germany
IŽd personally go with the bipole as well but just in case you get tired of those variations hereŽs another one:
http://www.creativesound.ca/pdf/ELF1.5DOC.pdf
with either of these filters:
jens
Sub for Tangband W3-871S ? Kees Subwoofers 1 23rd March 2008 08:20 PM
is the Tangband W3-871 the same as W3-871S michelevit Full Range 11 6th December 2006 07:09 AM
Tangband 871S (the 'Hot One') Tenson Swap Meet 1 13th August 2006 08:47 PM
Tangband W3-871S in the UK ? jives11 Full Range 3 15th May 2006 08:43 PM
TangBand W3-871S Jye Multi-Way 47 27th July 2004 06:07 AM
Page generated in 0.08168 seconds (72.46% PHP - 27.54% MySQL) with 10 queries
