Poor manís WR125? - Page 2 - diyAudio
Old 7th November 2005, 07:20 PM   #11
My friend built two pairs of Buschorn MK2 TB's, one pair with W4-655 and the other with W4-657. They're both very nice drivers, but will need some notch filters to fix the 1kHz and 7kHz spikes. Without correction they sound kinda awful.
I'm thinking of using the W4-657 in a 2-way with monopole tweeter and bipole midbass. They have quite good efficiency and Qts .38 for good BR. Although I'm still thinking if a Dayton RS125 or Aura NS4-255 would be a better choice.
Old 7th November 2005, 09:18 PM   #12
Default handling bass < 100 Hz for TV
Do others think sealed is desirable, to avoid bottoming out for TV use?
Maybe it depends somewhat on if youíre watching a doco, or MTV playing your favourite song (if that ever happens)?
If I did a sub to handle low bass, I'd want one with Q probably < 0.25 to go in a small box eg maybe only 20 litres. Any candidates?
Old 7th November 2005, 10:45 PM   #13
DDF is offline DDF  Canada
DDF's Avatar
Download unibox and do a quick sim of any vented box with this small a driver and high a box tune. You'll be shocked at how easily the wooofer bottoms vented, sometimes as quickly as a couple watts.
I think that the woofer easily bottoms in vented has to be true (the math don't lie), whether people find it sounds objectionable when it does is I guess what you're asking. I don't like it FWIW.
Old 8th November 2005, 02:57 AM   #14
Need an xo and (I donít yet know how big) a box, but a Dayton 295-315 http://www.partsexpress.com/pe/pshow...Number=295-315 would give nice bass and take the strain off even the 0.5 mm Xmax small fullrangers
Cheers
Old 8th November 2005, 03:13 AM   #15
DDF's Avatar
Check out the TB W6-1139SC. It seems to walk that perfect line for a sub that needs only 100 db peak o/p. Small box possible (10L or 12 L) and a good honest 35 Hz o/p. Only trick is that it needs at least a 2" port, and this will be in the 25 to 30cm length range, so it'll need to be bent or folded in the box.
I'll be using an 18L box, only so I can fit a straight 2" precision port with enough flow space around the port and driver.
Old 15th November 2005, 05:46 PM   #16
Originally posted by Josephjcole
Not the naturalness of my fostex 108, but at a quarter of the price and a larger power handling... not bad. I'm working on a pair of speakers using the W4-1320SB. It certainly looks to be a nice driver, and I have I hopes, but I haven't done enough listening to tell you more.
Joe
Joe,
Have you had a chance to evaluate the 1320SB? I'd be very interested in how they sound and what you're doing with them. I'm fumbling around for a driver to play with and this one has caught my attention due to its price. I've also considered the FE108EZ, but I'm concerned it will not give me the umph (volume-wise) I need to fill my room.
Thanks,
Paul
Old 15th November 2005, 10:37 PM   #17
Josephjcole's Avatar
Originally posted by Paul Ebert
Joe,
Thanks,
Paul
Well I've started constuction of the final enclosures which will be two ways crossed at 200Hz to a 10" driver. So I still cann't add any new insights based on listening. I have to say though that I love my 108EZ. I have it in a wide-range two way and am quite happy with it. What size is your room? The 108 does have a limited excursion and can start to loose it at high volumes and complex passages when run on its own. But really in a back horn it is a wonderfull driver and can really make music. In a two way I think it is even better. I wish I could tell you more about the sound of the 1320SB, give me a couple of weeks. Certainly the 1320SB will not require such a complex cabinet and will not put such a hurt on your wallet. In the end though I doubt the 1320SB will be able to compare in sound quality to the 108's.
we'll see I'm building test enclosures to try out a couple of things on the 1320SB so I'll listen to these and get back to you soon.
Joe
Old 16th November 2005, 12:35 AM   #18
My room is approx. 14' by 22' with 8' ceilings. I am not able to place the speakers close to a wall or corner due to a poorly positioned fireplace.
I do not play at very high volumes (well, occasionally...) and I would be very open to adding a (sub)woofer to cover the bass, though that might have to wait a while.
I listen to classical music, all types of classical but opera.
I'm not put off by complex enclosures, but I do have some WAF constraints (not too wide or deep, tall is OK).
Do you think it would work to use a pair of FE108EZs in the factory recommended enclosure, crossing over at, say, 100 hz to a separate (sub)woofer?
Thanks.
Paul
Old 16th November 2005, 03:22 AM   #19
Yeah the 108 should work well for you. Either the factory recomended enclosure or the Buschhorn (check out the thread for more info). Bringing a sub into the picture might be a good idea, but probably at a lower frequency, unless you are planning on using an active crossover on the 108's as well. In which case maybe a different enclosure would be good as well. But... yeah people seem to like the Buschhorn.
Joe
Old 16th November 2005, 05:40 PM   #20
Speakerholic
Cal Weldon's Avatar
Great little woofer capable of 35hz as mentioned, but deathly inefficient. Needs a plate amp or biamping to keep up.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Fr125 + Wr125 help Robertburchell Full Range 26 10th April 2008 09:59 PM
WR125 combing with MTM or TMM davidallancole Multi-Way 1 26th January 2008 01:11 AM
Wr125 Mtm dawaro Multi-Way 3 7th November 2006 11:31 PM
Wtb: Wr125 bjackson Swap Meet 0 8th November 2005 04:50 PM
Copyright ©1999-2017 diyAudio
