Has anyone tried this little 3" fullrange speaker? The specs looks quite good. Insanely good considering the price.
I was thinking about a 2-way system with this as mid/high and a lightweight 8" woofer with a crossoverpoint between 250 and 400 Hz. Do you think it would work? http://www.madisound.com/cgi-bin/ind...20017&pid=1757 |
#2 |
I'v got a pair in a set-up with a pair of T B W4-992S and run off my computer an they sound very good IMHO.
#3 |
Just got another idea for this project. What do you think about mounting the fullrange driver without any box behind it? I'll try to explain my idea...
Picture the complete speaker as a lower case "b" when you look at it from the side. You have the vented enclosure for the 8" woofer in the lower part of the speaker, but the front baffel continues upwards and the 3" driver is just mounted in the middle och the part of the front that goes over the bass enclosure. (It's not easy to explain something when english isn't your native language Wouldn't that create a fairly "airy" sound? |
#4 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Can I use the length of a full wave at the desired freq. to determine the area of the baffle?
#6 | |
frugal-phile(tm)
http://www.t-linespeakers.org/downloads.html the short answer -- IIRC -- was 0.25 x WL = minimum width. Driver Q and room placement all play a role so that is a very loose guide. dave
#7 |
I have studied the document briefly but I can't understand it. Where do I enter the data for my driver and wich sheet shows the oben baffle data?
#8 |
Speaking of width... does baffle height play a role?
Would a woodchuck bother to chuck MDF? |
#9 |
This may be more then you want but its along the same lines OB over a BR box http://www.madisound.com/pdf/fostexc...5k_tallboy.pdf
#10 |
I started building the speakers last night. so far I am half finished with one of the 2 speakers. There is one thing i wonder. Should I dampen the sides for the open baffle 3" fullrange or should i leave the boards naked?
| New Aurasound NS3 2-way | Timn8ter | Multi-Way | 18 | 16th November 2007 05:05 PM |
| Aurasound NSW1-205-8A | BoH | Multi-Way | 1 | 11th July 2007 05:26 AM |
| Aurasound | Tristanc1 | Multi-Way | 0 | 3rd March 2006 06:37 AM |
| Aurasound NS3-193-8A | mista2 | Full Range | 25 | 20th December 2005 03:37 AM |
| Page generated in 0.11803 seconds (75.02% PHP - 24.98% MySQL) with 10 queries |
