little fullrange magic
Old 28th October 2008, 12:26 AM   #11
adason is offline adason  United States
adason's Avatar
Hi Brisso57,
sorry, I did not notice there was question, I do not get notified about the posts. This is quite an old thread.
I still do have the drivers, they are mounted on open baffle roughly 1x2ft accompanied with little tweeter. This baffle is sitting on top of closed box woofer, I believe woofer is 12". They are being used in the basement, when I work on the speaker projects. Driven by whatever is around, currently Luxman receiver.
ed
Old 28th October 2008, 06:24 AM   #12
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Originally posted by adason
Hi Brisso57,
<SNIP>
ed
What is the tweeter that you are using?
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 28th October 2008, 09:18 AM   #13
Brisso57's Avatar
Hi Adason,
You might like to check out
http://www.diyaudio.com/forums/showt...44#post1639344
post #838
cheers
Doug
Old 19th November 2009, 12:17 PM   #14
Brisso57's Avatar
Originally Posted by adason View Post
hi all
just want to report this driver, a 3.5" sanyo 8 ohm 8 watts, R-S6879
when you come accross this driver, do not pass it, it sounds wonderfull
i was amazed how much music comes out of this little thingy
i just experimented with a small closed box and later with an open baffle and the midrange was so wonderfull and life like, that i ended up using it instead peerless driver for ht project
this driver is definitely designed as full range, it has quite an extended hights /although I ended up using a tweeter with it/
its bass is not deep, but it's there and in a small closed box actualy sounded pretty balanced
that's all
I just tried this driver (the one you pictured, with a flat dust cap) in a pair of zigmahornets.
Wow! Clarity sizzle and a surprising amount of bass too.
Prior to that I tried another Sanyo FE103A variant. That one has a domed dust cap. The flat-cap variant sounds much better.
cheers
Doug
little fullrange magicHide this!Advertise here!
Hk6600 Magic robo7 Solid State 2 25th July 2009 12:18 AM
The Magic of a Name 7N7 Tubes / Valves 9 1st December 2007 05:58 PM
Magic Capacitor tenderland Solid State 23 22nd June 2006 07:39 PM
Playing with a Magic Eye. Shoog Tubes / Valves 7 13th January 2005 09:33 PM
TAD - the magic drivers? amo Multi-Way 4 12th May 2004 04:49 AM
