DIY a MantraSound Horn?
Old 27th October 2005, 08:27 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by ScottG
The measurements will not of course take into consideration the modification needed for dipole operation - which should extend the response considerably.
Originally posted by tade
how about buy twice as many as needed, and use two of the drilled magnets per speaker. [/B]
Already did that. Fairly easy to do. They did not measure any differently.
I have recently aquired some microMonitors from Akai that use this tweeter (and a PR on the back)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th October 2005, 07:29 PM   #12
ScottG is offline ScottG  United States
dave
That is very strange.. considering that the rear air-space originally is almost non-existant. It may be that the sd vs. excursion is so minute that no matter what you do you'll not achieve an extended freq. response.
perspective is everything
Old 27th October 2005, 07:42 PM   #13
frugal-phile(tm)
planet10's Avatar
I was surprised too... but i trust the guy wih LEAP that did the measures.
dave
Old 27th October 2005, 08:16 PM   #14
GM is offline GM  United States
GM's Avatar
Greets!
Ribbons are like compression drivers in that they have a very high Fs for their potential BW, thus the rear chamber can be quite small for the effective diaphragm area and still be ~an IB acoustically speaking, making them ideal for BLH loading.
So what's Fs?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th October 2005, 08:38 PM   #15
frugal-phile(tm)
planet10's Avatar
Originally posted by GM
So what's Fs?
Kinda hard to tell...
I'll dig out the ones i have and do my own measures and see how they compare
dave
Old 25th November 2005, 07:56 PM   #16
Part Deux..
Looking over the BG Neo8 thread here I noticed member fcserei's contribution - in particular that his straight (though front loaded) horn in fact sounded better than the dipole version he worked with. (Also note the freq. response that was elevated from the horn which happens to "gell" rather well with the on-axis response of the driver.)
http://www.diyaudio.com/forums/showt...0&pagenumber=1
I'm thinking that just two drivers per side would work rather well with a back-horn, perhaps with an Aurum Cantus G2si to fill in the highest freq.s. (i.e. vertically top to bottom:Neo8,Neo8,G2si 1st order cap with the driver inverted to adjust for polar tilt.)
Well, just something more to think about here..
DIY a MantraSound Horn?Hide this!Advertise here!
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 06:29 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer thekop-bkk Swap Meet 0 26th September 2008 03:55 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
