#21 |
rcavictim: this question has come up, only question I ponder is how do I mount the clear sides on & visually pleasing (exposed screws)
jfieb: many questions here, this is not my design. Many of his techincal knowlege & ideas are yet to understood by me. The original Austins are designed by Ron, you can check out these threads, many of your questions can be answered: http://fullrangedriver.com/forum/viewtopic.php?id=214 in regards to smooth radiii, please check out this topic: http://fullrangedriver.com/forum/viewtopic.php?id=207 Skin, not sure what to put on it, maybe for this prototype, I'll put on some PE vinyl adhesive (hope i don't start any fires here) MDF - i've tossed around the layers, as long as you don't bend it forcefully, it will not break;even stronger when they're all glued together this is the latest thread: http://fullrangedriver.com/forum/viewtopic.php?id=303 These layers are cut with a CNC router (hope i'm not repeating myself) This is purely a prototype, standby for update, thank you |
#22 | |
A gasket of thin felt, color of your choice would look nice between the sides and the wood and would solve seal/vibration noises and eliminate possible long term abrasion scuffing of the inside of the sideswalls.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#23 | ||
This is the pic i was talking about. With external cabinet dimensions, and a side on view, like in this pic but straighter, and i can make plans for this. i dont have any flash tools, but i do have access to a router. I would probably cut each layer with a jigsaw and hand finish. More work, but hey, who cares. I used to make accoustic guitars so am used to tight tollerences working with wood. |
| Newbie intrested in repair and tweaking | kmfdm_mdfmk | Solid State | 6 | 10th November 2012 10:56 AM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| Anyone intrested in a DIY BOZAK preamp/mixer? | DJNUBZ | Solid State | 3 | 1st February 2006 08:48 AM |
| How many ppl are intrested in HiEnd DAC kit ? | foo | Digital Source | 45 | 30th August 2005 07:16 AM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 05:06 AM |
