8-12" Bass reflex Full range Corner speaker (mono)
I am looking to build a medium to high sensitivity mono bass reflex corner speaker with either a full range 8-12' speaker by itself or with a helper tweeter. What speakers would qualify? I would like bass down to 50 Hz and a bass reflex, as I do not have the skill to build a horn, nor have lots of money to spend. Would any 8 inch Fostex drivers work well? I would love to keep the driver cost to about 100 dollars, and have no problem with buying a vintage driver, if it would be a good choice. If I needed to add a tweeter, would a ribbon tweeter work well? I am looking for a wide dispersion, because it will be the only speaker in the room, and when listening to music, I will not always be directly in front of it. Are there any plans for a corner bass reflex for a full range driver? Could I make a suitable box by seeing how many liters would be optimal, and making one into a corner style encloser? Would haveing a wide baffle be detramental? I will be using a Fisher EL84 PP mono reciever that has been restored. The music will mainly be classical, jazz, and some rock.
Ben
Ben
100 bucks per side or 100 bucks total. That's not a lot of green, but the pioneer 8" would work okay for that budget. It's not that sensitive though.
I'm doing a version of the afterburner which uses a 12" eminence beta 12lt with a fostex ft-17h for the helper tweeter. Should make for a very nice speaker and really sensitive (around 96db/m). Could probably be built with the passive x-over for about 250 bucks for the whole shebang.
Nate
Nate
Nate_Taufer said:100 bucks per side or 100 bucks total. That's not a lot of green, but the pioneer 8" would work okay for that budget. It's not that sensitive though.
Nate
I have all the wood I need, so when I say 100 per side, I am thinking driver / crossover.
