Old 26th January 2013, 11:11 PM   #5141
xrk971 is offline xrk971  United States
xrk971's Avatar
It is probably an air leak at the bottom cap. I will try sealing with plumbers putty before gluing. Everything says it should work, it must be the seal...
Should be monster bass if it works.
Old 27th January 2013, 12:32 AM   #5142
GM is offline GM  United States
GM's Avatar
Originally Posted by Squeak View Post
Idealy a BiB should be pushed in a corner or at least have some half-space boundary loading, like ceiling and wall.
Positioned out in the open on a wall is considered 2pi [half space] loading:
True Audio Speaker Topics: Spatial Loading
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th January 2013, 12:34 AM   #5143
GM's Avatar
I guess I missed something....... how do you know it will have a lot of bass in 1/2 space? BIB requires at least 1/4 space loading AFAIK to protect the driver somewhat below Fs.
GM
Old 27th January 2013, 01:09 AM   #5144
xrk971's Avatar
My past experience with a BIB is that there is plenty of bass. Would mounting on a wall with mouth aimed at ceiling (3 ft away) count as 1/4 space loading?
Old 27th January 2013, 02:26 AM   #5145
GM's Avatar
As it should if at least up against a hard wall and at least 6 ft tall [~12 ft path-length] with an 8 ft ceiling; but yours is only around 5 ft, so no, 3 ft away is probably going to net you nothing in 1/4 space.
GM
Old 27th January 2013, 10:24 AM   #5146
Squeak is offline Squeak  Denmark
Squeak's Avatar
GM
Just a little OT question: When you talk about protecting the driver in this way, as you often do, you don't mean the resistive pressure actually stopping the driver from moving?
Rather you're saying that you don't have to EQ it so much to get the same bass, and thereby protecting the driver from over-excursion at peaks?
Am I right?
Old 27th January 2013, 12:11 PM   #5147
xrk971's Avatar
I think that the resistive pressure is what GM is talking about, although I don't see how a BIB with it's expanding wide open geometry and lack of a throat could ever develop enough resistive back pressure to limit cone excursion, although, if tuned to have resonance at correct frequency near excursion limit it could work.
Old 27th January 2013, 12:21 PM   #5148
xrk971's Avatar
Default Update on FIB build in foam core - air leak solved
Ok, good news, it was an air leak on the bottom cap. Once I sealed it, it sounds great! Nice bass and it couples to the wall very nicely. I had to line the flat surface behind the driver with a layer of open cell foam and added more stuffing into the triangle cavity above the driver. This improved the tightness of the bass. Less boomy. Anyhow, it was a good result and I am now proceeding with the second unit build.
Old 27th January 2013, 12:36 PM   #5149
Squeak's Avatar
My thinking exactly. The resonance effect would be quite weak and only work within a limited window.
Think of a long spring where a wave started at one end has to travel all the way to the end and back again. At some frequencies it could even make the problem worse.
Old 27th January 2013, 07:10 PM   #5150
kec is offline kec  United States
kec's Avatar
Xrk,
What final dimensions did you use? External and internal.
Intel D410 mITX > Foobar > Musiland 01 USD > Gigawork DAC > Crown XLS1000 > Manzanita Ultra
Copyright ©1999-2013 diyAudio
