Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks? - Page 316 - diyAudio
Old 7th June 2007, 01:25 PM   #3151
Scottmoose's Avatar
Default Re: CSS SD12 Subduction
Originally posted by planet10
Need a big subwoofer? In-room should be less than 20 Hz
Should make for an interesting listen...
"'That'll do," comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 7th June 2007, 01:38 PM   #3152
GM is offline GM  United States
GM's Avatar
Originally posted by Scottmoose
Neither are tapped. A tapped horn has the driver mounted through the internal baffle.
Greets!
I started to say this, but decided that the fact that DSL chooses to use the term 'tapped' to define its pipe horn loading technique doesn't change the fact that any TL, MLTL, horn, TQWP with the driver offset along its length is a tapped one.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th June 2007, 01:40 PM   #3153
Scottmoose's Avatar
I stand corrected. As ever, thanks for the clarification Greg.
Old 7th June 2007, 01:55 PM   #3154
edgebc is offline edgebc  United States
Will thomaseliot's design work?
Old 7th June 2007, 02:05 PM   #3155
GM's Avatar
Greets!
This reminds me, awhile back I did a fairly high gain SD12 ~16 Hz TQWP design at Bob's request that he said was turned over to you for evaluation, so wondering what the status is.
GM
Old 7th June 2007, 02:16 PM   #3156
GM's Avatar
Greets!
I don't see why not, per his notes the 206 is essentially a sealed back 'tweeter' in this case, so the drawing isn't accurate. For sure you can't have both drivers venting into the pipe or the woofer will audibly modulate the 206.
GM
Old 7th June 2007, 02:30 PM   #3157
Default Hello from Florida...
The reason I ask is attached.....I just finished these a couple of weeks ago after reading the first half of this thread. 84" tall-FE206e-wrapped in speaker cloth. After 23 years of maggies, I feel like I just made giant center channel speakers. I've been wondering about anding more drivers without calling it an array.
Would sealing one driver and then allowing the other the proper line length give a coherent soundstage? Bi-wired? These questions and more........Less than two months reading this thread and visiting your sites and homes in pictures and I feel like
I can build anything.....thanks.
Old 7th June 2007, 02:45 PM   #3158
Default Re: Hello from Florida...
Where is the picture?
Old 7th June 2007, 03:44 PM   #3159
Godzilla's Avatar
>>> Just one question for all 165K BIB builders :
>>> - does this BIB need a tweeter
>>> if so, what about Fostex FT17H used above 10kHz.
>>> Any oppinion welcome.
That tweeter is a great choice IMO.
Also, will that sub design work with the TB 8" subwoofer?
http://www.partsexpress.com/pe/pshow...number=264-854
Godzilla
Vive la musique!
My blog: https://speakerprojects.wordpress.com
Old 7th June 2007, 05:18 PM   #3160
frugal-phile(tm)
planet10's Avatar
Default Re: Re: CSS SD12 Subduction
Originally posted by thomaseliot
What I was waiting for?
FW208N
.... FE206E (with phase plugs) would be isolated from the BBIB (BassBIB)
You have those 2 8" drivers scaled down to look like 10 or 11" drivers, they should probably be a bit smaller.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
