#1781 |
Greg's B200 ML TQWT is somewhere on this monster thread. I'll try to dig it out.
The amps look fine. The horn kit you link to is similar to a Nagaoka design I remember. Not having the dimensions, I can't pass comment, other than to note that it's unlikely to go very low. Fostex FE206E in Ron's Dallas II, FE207E in Bruce V1.1 double horn (see near the end of the Spawn of Frugelhorn thread) or the FE208ESigma in the Factory cabinet would be my choice for a regular horn. Meantime, I'll try to dig out the dims of Greg's B200 MLTQWT |
#1782 | |
This technique does not work if the speaker opening is smallish, so I had to buy the Jasper with my 6" speaker. the Jasper works great. gychang |
#1783 | |
Thanks! |
#1784 |
Found it on page 13.
L = 113.38" SO = 2.036"^2 SL = 265.464"^2 xO = 0.6825 (77.38") density = 0.2 lbs/ft^3 rp = 3.25" lp = 1.5" Rounding these to the nearest easy values, and using Greg's nifty little Excel sheet to get a conical profile, not that it really matters much in this case as it's mass-loaded, will give you a line length of 113.5in, Zdriver of 77.5in, an internal depth of 19.5in (not including the sloping internal baffle), internal width of 13.5in, with a 3.25in diameter, 1.5in long port. I'd do this one inverted, so the driver stays at a reasonable ear height, with the port near the floor. Should be a cracking system. Big and musical. |
#1785 |
Dear Scottmoose
you are great sounds crazy and sorry maybe I'm dammed stupid, as all bl..nde >>Greg's nifty little Excel sheet is it anywaz on these zillion pages or may I send him email it's 00:39 going to bed now Régine a bit red wine and pizzas so l I do gess l= Lenght but the rest what the hell does it mean no idea in the moment and density oh my dear >> L = 113.38" SO = 2.036"^2 ??? inches and a fraction SL = 265.464"^2 xO = 0.6825 (77.38") density = 0.2 lbs/ft^3 rp = 3.25" lp = 1.5" most books I do read are german, have to be french and years of Speakerbuilder somerwhere in my old flat .......no keen do dig them out
" Glamour will never die ! " |
#1786 | |
The Hemps can have some of the same problem, but have a little more flexibility in positioning since they don't need to right back up against the wall and that can help. |
#1787 |
One1Speed
Yes, it is possible....but you must be good at hovering before the plunge. Ray |
#1788 | |
Original with notes in #240: http://www.diyaudio.com/forums/showt...709#post878709 BIB folding in #907: http://www.diyaudio.com/forums/showt...770#post945770 GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#1789 |
lousymusician,
Thanks for the info
#1790 | |
Thanks for answering. The Hole saw has served me well through a number of builds including a line array of 8 drivers. I have no router. But what I do have is a roto zip device which can hold router bits. The roto zip device also has a circle jig which I plan to use on larger cutouts. I'm familiar with the Jasper over the years of reading this forum. I'd like to get a good router some day. |
