Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks? - Page 114 - diyAudio
Old 20th August 2006, 08:50 PM   #1131
Tachyon is offline Tachyon  Sweden
Thanks Scott, more pictures will be posted later when ready.
Old 20th August 2006, 09:25 PM   #1132
dmason is offline dmason  United States
166ES-R BIB is about as good as it gets. Too bad there are not more of those drivers. I built the Fostex Rx backhorn for mine and what a machine!! I almost wish I hadn't sold them, to have those drivers for a BIB.
"Pilau Buggah, Big Islan Mo Betta!!"
Old 20th August 2006, 10:39 PM   #1133
edjosh23's Avatar
Tachyon,
Looks like you used Gorilla Glue. Right?
If so Gorilla glue expands and tends to look rather ugly when trying to put a finish on it. TiteBond or other similar wood glues will not expand and can give a better finish. Also once the Gorilla glue is sanded it is very porous.
Josh
Old 21st August 2006, 01:15 AM   #1134
Yes....but polyurethane (gorilla) glue does a very good job of filling voids!
Old 21st August 2006, 07:35 AM   #1135
Scottmoose's Avatar
Made from genuine gorillas you know.
I tend to use PVA for my projects. Though my finishing technique leaves a lot to be desired. Bomb-proof yes. Attractive? No.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 21st August 2006, 11:44 AM   #1136
Danne72 is offline Danne72  Sweden
Send a message via AIM to Danne72 Send a message via MSN to Danne72 Send a message via Yahoo to Danne72
Hej Tachyon.
What are your dimensions in cm?
D.S
Old 21st August 2006, 08:15 PM   #1137
Internal dims 19 X 30 X 172.5 cm.
Magnet clear 0.5 - 1 cm from internal baffle
Sm 88.33 in/2, a tad more than the recomended 87.75
I used 18mm birch ply.
Poly-glue was only used in the bottom that I had removed, the new piece fitted snugly and the poly-glue filled the minimal gaps.
Now I'm just gonna decide what tint I'll use in the oil.. Stone foundation will be slabs of black diabas so maybe a dark red would be nice? Anyone not coulorblind out there with some recomendations?
Old 21st August 2006, 08:20 PM   #1138
Hej Danne!
Do you have a pair of 166ES-R?
Old 21st August 2006, 08:48 PM   #1139
Hej.
No, would like to thou...
I have a pair of 164 and got lazy.. As i understand it, they chear the same dimensions im a BIB? Pleas correct me if i`m wrong!
Thanks for the dims thou
Mvh Danne.
Ps: Är du färdig? Hur låter dom?
D.S
Old 21st August 2006, 09:30 PM   #1140
I can't find any sims for FE164 on Zillas page...
maybe GM or Scott can do them if you ask nicely ;-)
http://www.zillaspeak.com/bib-fostex.asp
They are ready but not listened to yet, deciding what finish to use. My friend got this new power sander machine and we "uhm" grinded away to much of the outer veneer layer so one speaker got a big dark blotch that didn't really show until I put the first layer of oil on them. I will now tint them a bit, or a lot, darker. Live and learn as usual.
Copyright ©1999-2017 diyAudio
