Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
Old 8th January 2013, 04:56 PM   #5091
jhutka is offline jhutka  United States
jhutka's Avatar
Xrk,
Here's the drawings I worked from.
I build a little different from calculator because I like to build with a side down and after the guts are in, finish with the last side on top. The plans from the calculator have the sides tucked between the baffle and the back. I like to tuck the baffle and back between the sides.
Last edited by jhutka; 8th January 2013 at 05:04 PM. Reason: Added more information.
Old 8th January 2013, 10:46 PM   #5092
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Thank you Jhutka. I might try this in foam core first. qnty 5, 20x30 in sheets for both speakers. All rectangles, easy.
Old 9th January 2013, 03:43 PM   #5093
Godzilla is offline Godzilla  United States
Godzilla's Avatar
That's a small BIB!
I swap between the Fostex 127e and Dayton 5" fullranger (same hole size) in my smallest BIB (which is closer to four feet tall (whereas yours is less than three feet tall) and the sound produced by each driver creates a totally different and wonderful sound. Fostex smoother. Dayton bassier.
Old 9th January 2013, 04:50 PM   #5094
Got Foam?
xrk971's Avatar
Originally Posted by Godzilla View Post
That's a small BIB!
Maybe should be called Smaller Is Better (SIB)?
Old 9th January 2013, 08:03 PM   #5095
jhutka's Avatar
I've gone even smaller. Computer BIBs made with 1/2" material and
Tang Band W2-1803S (2") as drivers. They sounded really nice for desktop use.
In my naivete', I thought that any speaker I plugged into the calculator would work.
I've only been disappointed once. Great Design!
JH
Old 9th January 2013, 09:55 PM   #5096
Got Foam?
xrk971's Avatar
What driver did not work? I also want to make a 2 in driver bib in side by side stereo boombox config. Will visaton frs5 work? The tc9fd has little bothers: tc7fd and tc6fd that should work too.
Old 10th January 2013, 01:44 AM   #5097
jhutka's Avatar
Almost embarrassed to say that it was a HiWave Harp BMR that did not work as a BIB. I was shooting for the elongated aesthetic in an elongated box. Look was ok, but sound was not.
Still have the two speakers if anyone has ideas.
As far as using the FRS5, plug the specs into the calculator and see what comes out. (GM's post number 5017)
Old 10th January 2013, 02:52 AM   #5098
GM is offline GM  United States
GM's Avatar
Hmm, plugged the specs into WinISD Pro to see how well they matched up.....
These suggested a ~50 Hz tuning, so plugged these into the calculator except with a 97.42 Hz Fs and it came out like this, so if you want to try again it might be OK once damped.........
GM
File Type: gif HiWave HIBM130H10-8_LP revised specs.gif (13.6 KB, 359 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th January 2013, 05:06 PM   #5099
Got Foam?
xrk971's Avatar
GM
GM,
Which driver are you talking about here? The FRS5? The Fs on that is like 180 Hz...
Old 10th January 2013, 05:56 PM   #5100
GM's Avatar
I was responding to jhutka's HiWave post.
GM
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?Hide this!Advertise here!
