Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
Old 2nd July 2009, 01:18 AM   #4551
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Some consider the Orions the best speakers ever. There is a lot of technology there, open baffle, h-frame woofers, very expensive drivers, modern crossover design, powered components, extensive engineering, etc... BIBs are much more simple - single driver, cabinet integration, corner load, hi eff, no crossover... totally different beast but a beast no less... maybe an 8" BIB would be a more fair comparison? Regardless, both are excellent designs. Enjoy them both!
Godzilla
Old 2nd July 2009, 03:34 AM   #4552
Doc Jr 8156 is offline Doc Jr 8156  United States
Thanks Jeff. Samuel, please excuse the tone of my last post I did not realized that it can be read differently. I meant no sarcasm. I'm just trying to explain the difference between the speakers being compared.
Jeff, I ordered the 8 inch versionof the EZ and one day I will find a way to build another BIB. My problem is that I have 6 different Fostex speakers and I'm running out of space to hide them when not in use. I intentionally relegate my F200A as home theatre speakers just to apeace my wife. Godspeed.
John Revilla
Old 2nd July 2009, 08:58 AM   #4553
Samuel Jayaraj is offline Samuel Jayaraj  India
No, I have not heard the Orions. So perhaps, I made an unqualified speculative comment.
Perhaps, not in a BIB. However, with the FE168EZ in an OB like the 'Dark Star' with an 'H' Baffle subwoofer assistance, the combination should sound fantastic.
Or in a Moose BVR, an EnABLd FE168EZ should give a performance in a different league altogether. I am just waiting for the day when Scott and Dave would release an official BVR design for the 168EZ. For the present, I have mine playing in a QWL and they sound fairly good; the bass could be better. I plan to use a Fountek ribbon as a super tweeter, which I also have unused till date.
Sam
Old 3rd July 2009, 02:54 PM   #4554
filip_yordanov is offline filip_yordanov  Europe
Hello everyone!
I wanted just to show (off with ) the BiBs me and my brother built a few months ago. The drivers are FE206E and the amp powering them is a F2 clone.
With good records the sound is very voluminous, or spacious, don't know how to say that .
As the drivers are breaking in, I feel that I need to play a little bit more with the equalization network... and maybe play with the stuffing, but no time at the moment.
Thank you for the nice project and helpful instructions .
Old 3rd July 2009, 06:15 PM   #4555
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
You mean this one http://p10hifi.net/tlinespeakers/FH/...map-291208.pdf
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th July 2009, 04:26 AM   #4556
Originally posted by planet10
You mean this one http://homepage.mac.com/tlinespeaker...map-291208.pdf
dave
Dave, I had not seen the layout of the Ceinwyn-Chang earlier. Are these preliminary dimensions or has someone built, measured and listened to these?
Personally, I would have loved a curved profile of the horn mouth, just for aesthetic reasons, if not technical.
My guess is that these would have an in-room response of about 50Hz; or is my guess wrong? While I agree that the dynamic range of a horn is closer to emulating a live performance, how does one get a sub that goes pretty low to sound just as fast as an FR?
This is precisely the reason why I continue to use a quarter wave pipe; it helps me get response below the driver fs. Thanks.
Sam
Old 6th July 2009, 05:06 PM   #4557
Godzilla's Avatar
Cool design for the Fostex 168ez... wonder if it would work well enough with the older style 168z i have lying around in boxes?
Godzilla
Old 6th July 2009, 07:19 PM   #4558
frugal-phile(tm)
planet10's Avatar
Those plans were pushed to the top so that Peter Reinders could build a set. There is a thread somewhere here where he talks about his results,
Should be good to under 50 Hz. To get a sub to blend it has to have good HF response... a woofer as opposed to a dedicated subwoofer is usually indicated.
dave
Old 7th July 2009, 04:03 AM   #4559
Thanks Dave. I've sought Peter's impressions, as of now, on that thread.
Is there a curved profile I can follow for the horn mouth which might look better and not compromise on sonics?
Thanks for the input on sub vs. woofer. I have a pair of LAB12 drivers and quite a few of the other Eminence drivers, including 3015LF, Beta12LTA, HL10A among others. However, I reckon that I might have to look for a pair of woofers with enough Xmax and power handling and use them below resonance in push-push or pull-push configuration with electronic compensation. I am just a bit worried about colouring the sound with all of that electronic correction. Graham Maynard published a discreet circuit in EW which might be better than any op-amp based circuit such as Rod Elliot's.
It is due to this apprehension, I have been looking for a 'one box solution' with only a super tweeter to boot.
I am looking forward to Peter's comments and from others who might have built the Ceinwyn Chang and soon might be able to build a pair.
Sam
Old 9th July 2009, 08:18 PM   #4560
bump!
Sam
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?Hide this!Advertise here!
