Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
Old 21st July 2008, 10:52 PM   #4191
loninappleton is offline loninappleton  United States
Default mp3 test tones
http://users.swing.be/hdepra/home/P22/E-sounds.html
A quick and dirty test from this test tone site using only
40, 50 and 60 hz.
I then switched the leads on the channels. This effectively
gave the sound level a switch. The problem may be in my SS
receiver. But I want to do another test with a direct dvd input
which doesn't use the soundcard.
I have some more test tones on a cd. The prblem with those is when I
burned then to disk, the file names did not give any tone numbers.
One more levels test and I'll report back.
Old 21st July 2008, 11:02 PM   #4192
Default Noises off :-)
Well the sound level was the same using a cd played with the
dvd player.
I have another variable to check.
I'm going to rewire the two speakers the same. Currently the BIB
has the thin wire tweak... not quite magnet wire but pretty thin.
Old 22nd July 2008, 12:25 AM   #4193
Got the wire changed. Check.
Did a test using the RP U100 white noise generator in a sweep. Check.
Things sound pretty good. *But* I still have to retest with tones.
The tones were way off.
Next I swap the drivers. But I think all of this is just
confusing me. If the tone level swaps sides that means it's the
BIB.
To review: in tones (40, 50, 60) MLTL side louder, BIB not so good.
As it stands, I at least I don't think my amp/receiver or FE127es are bad. On the HD FM music stream through the soundcard things sound pretty good.
Old 22nd July 2008, 12:42 AM   #4194
rjbond3rd is offline rjbond3rd
Howdy Lon, do you have BSC on the MTLT?
Old 22nd July 2008, 03:24 AM   #4195
Nope. I have never made an xo in my life.
Old 22nd July 2008, 10:20 AM   #4196
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I though he was talking about BSC?
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 22nd July 2008, 02:39 PM   #4197
zayne742 is offline zayne742  United States
rjbond3rd ,
Do you have pics of your build yet?
Fliping Switches, Pushing Buttons, and Turning Knobs.
Old 22nd July 2008, 03:01 PM   #4198
Hi guys,
Scott, I'm totally stumped as to why Loninappleton's MLTL w/o BSC could have more bass than his BiB. Do you have a theory?
Zayne, do you mean in-progress pics? If so, I will take them. If you mean final pics, I will have those by the end of next week. I'm limited by only having four clamps. They won't be beautiful (!) but it will be interesting to test the FE166ES-R's in them (Paba, are you out there?)
Old 22nd July 2008, 05:07 PM   #4199
GM is offline GM  United States
GM's Avatar
Default Re: some tweakage is needed
Originally posted by loninappleton
Interior treatment is similar but not identical.
The BIB original is giving a better midrange whereas the
double front baffle (one cutout 4 in, the interior cutout 5 in)
gives the mids coming out the front a muted effect.
So suprabaffle on these.
I do not think minor surgery such as chamfering the inside baffle
would change this.
The original 'good sounding' BIB currently has the thin wire
tweak on it but here again I think this is minor.
Both use FE127e. Both are about the same same size and the
newer sibling is closer to the calculator measures.
What concerns me is what's coming out the front and less so
what is coming out the top.
Hmm, until all the variables of driver performance, etc. are accounted for, you can't really know much about the cab's performance and if I'm understanding you there's more differences between the cab than just a double thickness front baffle, further diluting the ability to pinpoint any perceived differences.
WRT chamfering Vs using a stepped flare, my measurably hearing impaired 65 yr old buddy recently had no problem perceiving the difference when I made some adapters to convert his RS 40-1354 MLTL over to CSS FR125S drivers, though as always YMMV.
Anyway, when you say 'mids', this can mean different BWs to different folks, so please expand on what you mean since it can cover from ~160 - 1280 up to ~5120 Hz depending on the source with only ~ an octave of it being in the pipe's passband.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd July 2008, 05:16 PM   #4200
Hi GM, may I ask if you saying that the stepped flare is an improvement because it gets the driver's magnet and basket further out of the horn / pipe? Or rather, that chamfering is smoother and sounds better than stepped flare?
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
