Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
Old 14th August 2006, 12:34 AM   #1121
dmason is offline dmason  United States
I know. This is the why, the how, and the holy ghost. 91db @ 30Hz. Jim, they must sound amazing. Do the plugs next.
Imagine what full-on orchestral dynamics sound like, with these and a fast amp playing something like Bernstein conducting, "Rodeo" ...but in your living room.
"Pilau Buggah, Big Islan Mo Betta!!"
Old 20th August 2006, 06:46 PM   #1122
Andrewbee is offline Andrewbee  Jamaica
hi all,
has anyone built the bib for the Fostex fe-166es-r yet?
Using GM's excel spreadsheet calculator I get this but am concerned about the biga$$ magnet that it has and if it will actually fit. I know I can juggle the figures but if someone has already done it I see no need for me to reinvent the wheel.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 20th August 2006, 06:57 PM   #1123
zobsky is online now zobsky  India
zobsky's Avatar
Originally posted by Andrewbee
hi all,
in case it doesn't fit, you could always build a spacer baffle to increase the distance between the back wall and the magnet
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 20th August 2006, 07:26 PM   #1124
Zobsky and all,
I just whipped out the graph paper and did a quick scale drawing. It will NOT fit so the
extra baffle will be needed. I was planning on putting on some wings anyway so will incorporate them into the extra spacer baffle.
Old 20th August 2006, 07:41 PM   #1125
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That's the only problem with sticking to the ~ideal conical expansion rate -you'll usually need an additional baffle to get sufficient clearence. You can shift to a different rate -TC's original used a WxD ratio if 1:2.1 for example. How audible the differences between different expansions are is an interesting question. I suspect minor differences won't be that audible, though using Greg's spreadsheet should give the theoretically optimal results.
There has been a 166ES-R BIB (Clarke -you out there?) with considerable success I gather.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 20th August 2006, 09:11 PM   #1126
Tachyon is offline Tachyon  Sweden
I'll get the measurements on my BIB's with 166 ES-R tomorrow, the magnet is free by one cm.
For those who remember my missunderstanding on the clearance of the internal baffle at the bottom, I decided to take the bottom out and grind away that extra cm at the end.
I'm now in the process of oiling them with chinese wood oil and some pigment. I have ordered two black stone slabs to use as a plint for them to stand on.
Old 20th August 2006, 09:14 PM   #1127
Old bottom out..
Old 20th August 2006, 09:16 PM   #1128
New bottom fits like a glove..
Old 20th August 2006, 09:25 PM   #1129
Clearance around driver
Old 20th August 2006, 09:27 PM   #1130
Scottmoose's Avatar
Oh yes indeed. Very nice. Scott likes.
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
