Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
Old 9th August 2006, 06:38 PM   #1091
peterbrorsson is offline peterbrorsson  Sweden
Hi GM and Scott!
Thanks for the replies!
Well sort of expected it, regarding upward move. Nothing is free here in life except joy and happiness (well, that's gonna be taxed sooner or later)
Have been thinking about paper made eggcraters below driver with some acousta stuff behind the pyramids. The pyramids would be perforated and also the tops chopped off.
Instead of deflex pads it could also be done with silicone glue scraped out in circles with a rake. Similar to what one use when putting up tiles in bathrooms. Lots of thoughts, not enough time.
Cheers
Old 9th August 2006, 06:44 PM   #1092
Must clearify about the silicone, it should be the quality which is rubberlike when dried. The reference to bathroom tiles was about the rake. I don't know if it's the right name but it makes potatoe fields:
Cheers
Old 9th August 2006, 07:36 PM   #1093
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
SoudDomain is down, so I can't host on my website, but here is a picture of my BIBs with a little paint on them.
Thanks,
Josh
Old 9th August 2006, 09:52 PM   #1094
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Nice work. One for the pages, Jeff?
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 9th August 2006, 11:10 PM   #1095
GM is offline GM  United States
GM's Avatar
Originally posted by Scottmoose
You might want to try increasing the stuffing in the point above the driver, which should help kill some of the unwanted HF. Although in a positive tapered pipe / horn like the BIB, I'm not sure if the usual QWR rule applies: the point of maximum velocity for the LF occurs at the terminus, and closer to the sealed end with increasing frequency. Greg?
Greets!
Just as max loading (highest pressure) is at the closed end, it's where stuffing has the greatest impact on attenuating the widest BW, ergo at the terminus where it's at the lowest pressure (velocity maximum), it has the least effect, so it boils down to how much LF roll-off is acceptable to damp its harmonics. To ~'have your cake and eat it too' will require a BLH filter chamber. If nobody beats me to it, maybe one of these days I'll have time to work up a BIB BLH variant. In the meantime, in a previous post I discussed using low SAF damping filters above the terminus to 'trap' some of the unwanted mids/HF output.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th August 2006, 01:21 AM   #1096
ChrisMmm is offline ChrisMmm  New Zealand
Default FE168 BIB
Quick question on damping.
My reading tells me you stuff the point above the driver and a 1" layer on the base with some felt behind the driver. What is the best stuffing material? I have some long haired wool (from ancient TL project), dacron and wool based house sound/heat insulation. For the base the wool based insulation would be easiest while the point would be easier with LHW - sound OK? The felt - in the past I have used carpet underfelt but this may be a bit thick (driver VERY close to internal baffle). Maybe a few layers of thin felt from a fabric suppliers? Not sure what would be best here.
TIA, Chris
Old 10th August 2006, 07:06 AM   #1097
Scottmoose's Avatar
Thanks for that Greg
Chris, what you propose re the stuffing sounds fine to me. There's very little difference between the respective damping properties of different materials, at least in audio applications, providing excessive quantities aren't used, so you should be fine. The layers of felt behind the driver might be a better bet than one thick one, if it puts said driver too close to the internal baffle.
Scott
Old 10th August 2006, 08:39 PM   #1098
Default FE168 BIB
TIA, Chris
Old 10th August 2006, 08:43 PM   #1099
Default Huh?
Sorry about the extra post, seems to have happened as result of using the back and referesh keys???
Old 10th August 2006, 10:34 PM   #1100
Scottmoose's Avatar
Odd. Similar things have happened to me. Machines! You can delete though providing you get it in time (30 mins after posting) -go to edit, and have a look at the top: you'll see a delete post button.
Scott
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
