Make the room part of the horn - diyAudio
Old 17th October 2005, 07:12 AM   #1
Default Make the room part of the horn
The drawing shows just the basic idea, do not criticize proportions, etc. It is a slim and very tall enclosure with a folded horn and the opening at the top. When mounted in the corner of the room, the ceiling and the two adjacent walls would form the last section of the horn. I think the radiation from the top corner of the room would have an adequate pattern.
The cross section of the enclosure might be square or maybe right triangular, though this one would be harder to build.
I am a novice, but am really excited about it and intend to try and experiment with it in the next couple of months, unless you tell me it sure won't fly.
Thanks,
Michael
Old 17th October 2005, 10:37 AM   #2
bobhayes's Avatar
I don't know whether you've seen this site, but your idea looks very similar to this.
http://melhuish.org/audio/DIYTQ8.html
Lots of good ideas and helpful mathematical programs to help you design a good horn.
Hope this is of some use to you.
Good luck with the project.
Old 17th October 2005, 01:25 PM   #3
Onur is offline Onur  Belgium
Onur's Avatar
Send a message via ICQ to Onur Send a message via MSN to Onur
Default why think in 2D
I have this design of mine which is using the floor and the side walls as the part of the horn, just like Motorola horn tweeters.
Since you can not shape the walls by means of a mathematical function, you give the enclosure a shape that it will work as a horn when it is placed at the corner.
But the question is, is it easy to find two perfect corners in every house?
(A picture will follow)
Onur
Master is the master of his own Happiness
Old 17th October 2005, 02:20 PM   #4
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Default Re: Make the room part of the horn
I see what you're trying to do but isn't this the aim of any horn design anyway? Still, it looks like a design worth building and experimenting with
"A squid eating dough in a polyethylene bag is fast and bulbous, got me?"
Old 17th October 2005, 02:51 PM   #5
maxlorenz's Avatar
A big horn at the corner of the room acts like a Helmholtz resonator, wright? I imagine you will have to study the room's response after designing it. Intuitivelly, that is.
Good luck!
Old 17th October 2005, 04:55 PM   #6
Onur's Avatar
Default Here is the Picture
Maybe it may clerify what I was trying to say. The dark spot is directed towards one of the corners of the listening room. At a certain distance form the end point is the speaker unit. It is easier to imagine the enclosure at the corner, making 45 degrees from each edge combination.
Old 17th October 2005, 10:17 PM   #7
Scottmoose's Avatar
Thanks,
Michael
This is a TQWT, not a horn. Most 'horns' aren't really horns at all, but variations on the TL theme, not that that matters.
It's an interesting idea. Try using Terry's dimensions (see Post 2) using either the Fostex FE166E, FE167E, FF165K or FE168ESigma. I have, and it shouldn't work -the driver position's all wrong, the drivers aren't right, the sealed end comes to a point, the large end terminates in free space etc etc etc -but it does work. And it thunders, especially if pushed into corners. There's ripple, but it's not as bad as the model predicts. I've just added a new post about this cabinet, because I think it's time we looked at it again and try to figure out why it works, despite the fact that it apparantly shouldn't.
Try it -it's easy enough to build, and doesn't cost much in materials -rough a pair up in MDF, and see what you think. They're more characterful than many speakers, but that's not always a bad thing, and they're certainly fun to listen to. If you don't like it, it won't ahve cost you much, and you can do something else with the drivers.
Best
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 18th October 2005, 06:36 AM   #8
Bob and Scott,
I tried that link and cannot see any of the pictures on melhuis.org. Is the website down or what? Anything I try there, I can only see text, but no images.
Will start building in few weeks, first I need to build some kind of hood around my table saw to reduce dust spreading.
Thanks for your comments!
Old 18th October 2005, 08:05 AM   #9
Scottmoose's Avatar
Ha! So it's happened to you as well!
No, seriously, on a couple of occasions in the past I've had the same problem, and I'm blowed if I can work out why -I don't think it's the site that's down, but what it is actually is, I don't know. I have the text and images copied into a Word file however for my own reference, so I'll send it to you if you like -send me a private email if you want a copy.
Scott
Old 18th October 2005, 01:43 PM   #10
bobhayes's Avatar
The site looks ok to me but some of the pictures take ages to load on dial up.
Give the page a minute or two and see if anything happens. If not... dunno.
Try using someone elses computer?
Hope you get to see the site, it's very good.
How to make a horn flare? Bill poster Full Range 0 11th June 2008 10:14 AM
Suggestions for 8000 cu ft room; K horn main speakers bigeasy Subwoofers 6 9th August 2007 05:40 AM
Not sure how to make a front/back loaded horn work ? audioaction Full Range 9 1st April 2006 06:59 PM
JP2.0 Part IV A.K.A. first test photos don't make fun of my cardboard DIY_newbie Multi-Way 24 1st September 2005 05:05 AM
dB Room gain in a midbass horn rick57 Multi-Way 2 13th January 2005 12:34 PM
Copyright ©1999-2017 diyAudio
