fr125s for in wall use?
Old 13th October 2005, 12:40 AM   #1
johnmark is offline johnmark  Abu Dhabi
Default fr125s for in wall use?
A friend has asked me to install speakers for his home theater in-wall and I was wondering if I could use 5 of the FR125 running full range.
I might consider using a crossover and tweeter on the fronts to improve off center response.
I think I could configure them to small with the yet to be determined HT receiver and fill in the bottom with sub. If i had him purchase one of the newer receivers that feature some auto-EQ, then the frequency response might be made quite acceptable.
I have not seen any posts about in wall use.
Any suggestions?
Old 13th October 2005, 03:08 AM   #2
CSS/XBL is offline CSS/XBL  Canada
I think this would work well. The round grills which come with one of the available options were partially designed with this in mind.
Bob
Old 13th October 2005, 10:40 AM   #3
Landroval is offline Landroval  Finland
I have been thinking of FR125 or 2xWR125ST+tweeter on-wall speakers. I've planned these on my mind for awhile, maybe I'll get something done...
BTW, is there a picture available of those new round grilles. What color? can they be painted?
Old 6th November 2005, 12:02 AM   #4
Default FR125's in wall system being built
I am still in the process of installing the complete in-wall / in-ceiling HT system for my boss. The Left/Right/Center will be in wall and the rears will be in ceiling.
I have also decided to use a pair of Adire Extremis as in-wall subs.
This will be a fairly low volume but high quality system for an older gentleman. I am using the newer Panasonic all-digital HT receiver as it is very compact and has been highly reviewed. It will not drive low impedance speakers however, so the FR125's should match up well.
Have not decided on plate amp to drive the twin Extremis yet.
Will probably choose to croossover around 150hz.
I cut custom baffles to place on the wall from 1/2" birch ply and they will be flush when the sheetrock is hung around them.
Will post pictures and listening impressions soon.
JohnMark
Old 19th November 2005, 02:34 PM   #5
jgwinner is offline jgwinner  United States
Sounds interesting - so you're just mounting the speakers in the wall so the 'speaker' is essentially the space between the subs?
What kind of AV does he have, is it a projector or plasma (LCD)?
How is the off axis response on these drivers?
== John ==
fr125s for in wall use?Hide this!Advertise here!
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
FR125S for in-wall surround firestream99 Full Range 18 18th January 2007 07:04 PM
CCS FR125S Options for a wall mounted design? BL21DE3 Full Range 13 25th March 2006 10:42 AM
Copyright ©1999-2017 diyAudio
