ML-TQWT modelling the B102 question - Page 2 - diyAudio
Old 8th October 2005, 03:18 AM   #11
Wish I could get deeper response (F3 looks to be about 50 hz). Any suggestions?
Thanks.
Paul
Old 8th October 2005, 04:13 PM   #12
Bob Brines's Avatar
Try this on for size.
The MathCAD worksheet looks like this
Bob
Old 8th October 2005, 11:50 PM   #13
amt is offline amt  United States
Bob, that looks pretty flat. I notice that the software version I have doesnt include the extra resistance field, and yours doesnt include the driver placement field. Where is the driver placed, or have I overlooked something?
Martin, so the BSC is really manditory for this drive, or else the frequency response will really be down by 3-4 db below 100hz or so?
Paul, Ive been eyeing this driver for a couple years, but once the Druid made its debut, I felt compelled to try and use it. A friend thats bass savy has said that they are a nice sounding speaker and has listened to the them numerous times. I will probably use a Fostex FT17H.
amt
Old 8th October 2005, 11:52 PM   #14
That looks great! Can you explain why a shorter box went deeper? Seems counterintuitive to me.
Also, will a 4" port be big enough? There's not much excursion going on, so perhaps chuffing will not be a problem? I figured I would use multiple ports.
Thanks!
Paul
Old 9th October 2005, 12:33 AM   #15
MJK is offline MJK  United States
The response looks much better.
I think Bob just editted the original file. If you have a full version of MathCad you can set up the input area in any way that is convenient.
Yes, I think some form of baffle step compensation will be needed to produce a balanced bass output.
Old 9th October 2005, 03:46 AM   #16
GM is offline GM  United States
GM's Avatar
Greets!
BB,
FYI, the Qts calc is wrong due to the need to subtract 'Rs' from 'Re' in the Qes field, so the additional formula should be either Re/(Re-Rs) or MJK's Re*(Re-Rs)^-1
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th October 2005, 03:55 PM   #17
Bob Brines's Avatar
amt
I did indeed edit MJK's worksheet to add the Rs fields. Also, you can do calculations of the right side of the screen to confirm area, etc.
The driver placement is xo in the Closed End of Transmission Line section.
Thanks!
Paul
The whole combination of driver Fs/Vas, length, geometry and post size/length determines the shape of the FR plot. In general, a 40" straight MLTL or low taper TQWT will have F3 in the 40's.
The larger the port, the stronger the high order harmonics. You want the smallest port that you can live with before port noise becomes a problem. Given the low power levels this design will encounter before significant distorting sets in, 4" should be adequate.
BTW, one hint that your design needs some work is that you needed 0.6 lb/ft^3 stuffing to flatten out the humps and valleys. If you need more than 0.25 lb/ft^3, rethink what you are doing.
Understand that I spend maybe 15 minutes modeling this design. You should take this as a starting point and go from there.
Originally posted by GM
Greets!
BB,
GM [/B]
Oops!
Fortunately, the resulting plots are nearly identical. I've replaced the pdf.
Revised MathCAD worksheet
Bob
Old 9th October 2005, 05:43 PM   #18
GM's Avatar
Greets!
FYI, since neither sections are 'locked', you can cut n' paste the 'X0 = L*x.xxx' into the 'ML TQWT Geometry......' section if you prefer.
Hmm, the way I calc them, I get the same FR plot except with a slightly smoother (though I imagine inaudible) HF BW with a much shorter straight ML-TL and slightly longer vent:
L = 26.1"
SO/SL = 171.434"^2
X0 = L*0.466
rp = 2"
Lp = 3.5"
same stuffing density/location as yours
Anyway, FWIW from my own stone age (minimal/coarse measurements) research I concluded that the pipe length basically just reduces the vent length, net Vb determining the shape ('fullness') of the FR/roff-off slope with driver location (and taper if applicable) determining the overall smoothness. This assumes the vent is near/at the bottom.
Hmm, I deleted both 'Qtd' calcs and the WS seems to work fine, with no obvious changes that I could see, so just brought it to your attention in case you/others used it for doing 'effective' Qts calcs.
GM
Old 9th October 2005, 09:07 PM   #19
Bob and Martin,
Thanks so much for your help. I'm learning some good info, here. I've got a lot of more general questions related to full range design (definitely, a novice). Since I don't want to hijack this thread, I think I'll take those to a new one.
There is one thing I'm curious about regarding the B102. An obvious difference between it and the driver used in the Druid is the aluminum phase plug. Ignoring the issue of making such a plug, is adding one something that can be done DIY? Also, what does such a plug buy you?
Paul
Old 10th October 2005, 02:02 AM   #20
I have no idea what the B102 driver is but I am sure a phase plug could be added in some form. Either a shaped plug or a socket head seems to be used most often. If you look in my gallery I added a picture of a homemade phase plug for a Lowther DX4 ML TQWT design. I have also seen people suspend a ping-pong ball in front of the driver, so suspending an object might be a method that does not require altering the driver if that is an issue.
I have experimented a little with phase plugs on my Lowther drivers. I have listened with no phase plug, the original bullet phase plug, the "shower head" phase plug from the DX4s, and a lightbulb phase plug from one of the horn applications. The light bulb phase plug seemed to degrade the high end sound. There was not much difference with the other three and if anything the original bullet sounded marginallly better then the other options. These are my opinions for my drivers in my room, your driver and situation might yield different results.
TL/TQWT conceptual question aceinc Subwoofers 7 26th May 2007 03:19 PM
Quick ML TQWT question Volenti Multi-Way 1 5th February 2006 04:32 PM
Question about modelling Lpads in LSPCad morbo Multi-Way 2 11th March 2005 06:55 PM
please help with this TQWT modelling with corals flat 8 DonJuan Multi-Way 9 13th October 2004 08:27 PM
TQWT Question Rino odorico Multi-Way 8 6th February 2003 02:14 PM
Copyright 1999-2017 diyAudio
