I want build horn that rich 40hz for my future Fostex FE206E
Is there anyone build KleinHorn from PassLabs? Any experience? Thank You! Best Reggards Niki / Bulgaria |
#2 |
Anyone?
Mr.Nelson Pass maybe?
#3 |
Seems like a "no holds barred" rearhorn, but not terribly practical.
If I had a pair of FE206E and wanted to build a rearhorn, I would: (1) Build the Dallas II horn. It is optimized for the driver. (2) Do the Decware phase plug mod. I've done it for my FE207E and it really smooths out highs. |
#4 |
Thank You for Your reply...
I know about Dallas II ... and this plan is one of my choices... But for Decware mod, i don't have sheme or similar for doin'it? |
#5 | |
The plug is simply a 15/16" socket (3/8" drive), standard length. Find the closest equivalent in metric, should work fine. Below is a drawing that I believe is proper scale. You need to remove the dustcap, careful work with a hobby knife works fine. When putting in the socket, grab tightly, it really goes for that magnet. As you can see in the drawing, the small hole (i.e. wrench side) goes out. Once it's grabbed the magnet, use a screwdriver in the hole (careful) to center the socket. I was very reluctant to cut my drivers, but am very pleased with the end result. Also, the chrome actually goes quite well, visually, with the driver. Tell your friends that it's a concentric tweeter.
#6 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Thank You for Your explanation
![]() I know about Your phase plugs planet10, and i have two similar that i've made it for experimenting with my fullrange Visaton BG20 This is my project for folding voigt pipes with these speakers... But i really think that decware mod is better because of "floating" sound waves below their mod. I think that Your phase plugs are art, but they make sound more directing to the listener and in consequence of this driver acquire more sensitive for moving on axis... even in 30 degree. |
#8 | |
#9 | |
frugal-phile(tm)
dave
#10 | |
BTW apologies for the redundant "space void".
| Experience with this DIY DAC ? | ah-luo-ko-ko | Digital Line Level | 4041 | Yesterday 03:36 PM |
| KleinHorn download | Nelson Pass | Multi-Way | 17 | 29th July 2010 04:05 AM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
