Tb W4-1052sa
Tb W4-1052sa
Old 26th December 2005, 08:44 AM   #21
greenie512 is offline greenie512  Australia
Originally posted by Jeb-D.
Keep us posted, I just got 4 of these drivers as well and am unsure exactly what to do with them.
Jeb, I don't want to post a load of detail here, I'll just report on final construction/sound. But if you are interested you can follow "work-in-progress" at http://www.greenie512.net/greenie512/html/wip.html where I'll post pics over the next week of build process.
Cheers - Phil
Old 31st December 2005, 01:06 AM   #22
Default build progress
Finally have one box build, wired and just running in. If you are interested in the fabrication see .. http://www.greenie512.net/greenie512...uction_w4.html
Currently one side is my Seas Thor TL's with the little W4's running on the other side not a very good balance but couldn't wait to hear a least one box. First impression was their efficiency - sound louder that the Thor on the other side at low/mediam volume. I've put biwire sockets in rear and am currently running speakers as bi-amped 4 ohm's but with a few jumper leads will play around with serial 8 ohm and parellel.
Sound are very good, but as an unbalanced pair can not really say yet what sound stage/depth etc are like.
Will try and get box No 2 finished during the week.
Cheers - Phil
Old 3rd January 2006, 12:10 AM   #23
Default Pair complete
Couldn't live with running one box, so finished second yesterday. The advantage of +40C in the shed is your glue cures dam quick!
I've put my comments on sound at the bottom of the construction page -
Cheer Phil
Old 3rd January 2006, 01:14 AM   #24
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
Very nice.
I'm glad you like them. How are they compared to your Fostex?
Josh
Old 3rd January 2006, 06:33 AM   #25
Originally posted by edjosh23
Very nice.
Josh
Josh – tell me say firstly this is “totally subjective” each pair of speakers were driven by different systems (but good un’s), one box is BR the other is BLH etc etc.
Okay, I’d say difference is very marginal, that close I think it’d come down to personal preference.
• TB’s reveal slightly more in the upper range and give better “shimmer/ting/crash” to cymbals/tops hats etc.
• On initial hearing this make TB’s sound more “forward” than FE 126e’s but TB’s sound is even overall and they don’t sound tiring!
• I’ve always like Fostex (human) “voicing” so FE’s win here but only marginal – the TB’s are very good.
• The BLH gives the impression of more bass but if I put the FE in their BR box I’m guessing there wouldn’t be much difference.
I think “joe public” would plum for the TB’s because the FE appear more mellow but with a good pair of ears you realize there’s not much in it.
Cheers – Phil
Old 30th March 2006, 12:18 AM   #26
type is offline type  United States
Cheers – Phil
greenie512,
So it looks like you feel like the 1052 is almost as good as the 126e. That's an interesting driver. You would never think that it was that good based on the manufacturer supplied frequency resoponse.
Old 30th March 2006, 12:49 AM   #27
edjosh23's Avatar
I don't think the responce is half bad. It's not flat, but responce curves for drivers such as the FE166R aren't so smooth, but I think there is a bit more than just responce graphs.
Josh
FE166ES-R graph below
Old 30th March 2006, 07:52 AM   #28
Type, I did say my comments were totally subjective – which reads “use your own ears”. This was a total free-form experiment that worked better than I thought it might.
For the cheap price of these drivers they work well and above their price range. There are probably even better speakers at this price, I just happened to try them.
I like them but they can not exactly replace my Seas Thor TL’s and after veneering and finishing they were sold on eBay.
Final boxes … http://www.greenie512.net/greenie512...ished_w4s.html
Cheers - Phil
Old 3rd August 2006, 03:47 AM   #29
edjosh23's Avatar
I saw that Scottmouse designed this in another thread and wanted to reprint it here as well. Thanks
Originally posted by Scottmoose
Well, here's one idea: a max flat (large) stand-mount:
20in tall
7in wide
8in deep
2in port, 4in long, 5in up from internal base on either the front or rear baffle.
Driver centre 5in down from top. (all internal dimensions)
Stuff 0.5lbs ft^3 of dacron or similar from the top to just above the port.
I don't normally bother with max-flat any more, but a standmount is often quite a good candidate for it -it'll add a little weight to proceedings. If you want to roll things off a little more, increase the port length by 1in.
Old 29th August 2006, 08:37 PM   #30
indoubt is offline indoubt  Netherlands
indoubt's Avatar
I know I'm kicking an old topic.
The reason for it being that I would like to know whether the dual drivers interfered with each other and whether this was audible. Ussually the theory says one driver for a frequency or a lot of drivers in a line array but than bassically from down the knee to over the head (if done right)
Is my understanding correct that you made a two driver crossoverless line array and that it worked like a charm as well?
better be indoubt untill you're sure
Tb W4-1052saHide this!Advertise here!
TB W4-1052SA in OB? 00600 Multi-Way 6 15th September 2007 06:38 AM
w4-1052sa modifications dgoodier Full Range 1 18th February 2007 01:31 AM
W4-1052SA vented raul_77 Full Range 6 12th April 2005 03:11 PM
MarkMcK's TB 1052sa Mod #2 bwbass Multi-Way 4 9th January 2005 06:19 PM
Tb W4-1052sa smbrown Multi-Way 4 20th July 2004 04:05 AM
