"Cyburgs-Stick" featuring W4-655SA
Old 21st May 2007, 08:55 AM   #21
alspe is offline alspe  Finland
I've made Cyburgs Sticks too. I did box 1 cm smaller in width and 1 cm bigger in depth. Volyme and tuning are same. Enclosure is 16 mm MDF finished with real birch veneer.
Sound is... How I can say? Bass is very strong even in my 20-30 m2 room. But I'm not pleased with midrange and treble. Highest treble has fade off and midrange is not very detailed. Of course we are speaking about 22 € speaker. Total cost for pair is about 130-140 € because of high quatily components ja box materials. Good thing is that girlfriend likes looks :-) First comment when amplifier was off was that they look nice! Women....
I've listening them for a couple of hours and they might sound better later when rubber surrounding has softened.
Here is links to my pictures and project (in finnish).
http://picasaweb.google.com/ali.maki...istatTBW4657SC
http://www.dvdplaza.fi/forums/showthread.php?t=58678
Old 22nd May 2007, 12:12 PM   #22
gychang is offline gychang  United States
Originally posted by MuaDibb
If you have the 871S already, I would suggest a downward firing BIB. If, you can put them in corners.
I am in the midst of building this BIB (unfolded 7 ft design), would like to see a separate thread especially if you have pictures...
gychang
Old 22nd May 2007, 10:09 PM   #23
Cyburgs is offline Cyburgs  Austria
@alspe:
Very nice woodwork, these are one of the nicest sticks I've seen so far!
Unfortunately I am not surprised that you are not satisfied with the sound they produce, although you did everything right, except one essential thing: You took the wrong driver!
The Stick is constructed for the W4-655SA, it will also work well with the W4-655A, which has nearly the same parameters, but the W4-657SC is a totally different animal.
If you look at the basic parameters (both measurements from german diy-loudspeaker magazine Hobby-Hifi which delivers very good measurement data in my experience):
W4-657SC: fs 46 Hz QTS 0,36 VAS 10 l
W4-655SA: fs 72 Hz QTS 0,36 VAS 4,5 l
You see that these two drivers need totally different enclosures. The W4-657SC needs only a simple and quite small BR-enclosure to give nice bass. The double bass reflex enclosure of the Stick is seriously misaligned for this driver.
The frequency response of the W4-657SC is also not compareable with the W4-655SA. It has some quite heavy dips and peaks, where the W4-655SA is quite smooth. So the correction filters of the stick do absolutely not fit to the W4-657SC, which furthermore is, and I may quote Hobby-Hifi again (translation by me): "Although the W4-657SC of Tangband is only a mediocre Fullrange speaker, it is an excellent midbass driver, perfect for a small monitor speaker with Highend-ambitions."
So I can only strongly suggest to equip your very nice speakers with W4-655SAs, then the sound will fit to the optical impression. :-)
Nice greetings, Berndt
edit: And please use black screws ;-)
Old 23rd May 2007, 04:49 AM   #24
OK, thanks for advice.
I knew that driver is (slightly) different but time when I bought driver's there were no W4-655SA's in Finland. I thought that 657SC's would be enough close. I'm often too optimistic
I got advices from finnish fullrange builders and they think that there's too much damping in enclosure. Yesterday I take some off and sound became much better. Now there is no damping in side walls of upper box.
Now I can buy W4-655SA's, finnish retailer had those now. W4-655SA's Is that correct driver?
Now my Sticks have strong bass but it's a bit boomy. Midrange is little too low level and undetailed, like singer being behind curtain. Will bass be strong with W4-655SA even it has much lower Fs? But quality comes first
I will use black screws and will do black fabric front grilles.
-Ali
Old 23rd May 2007, 11:23 AM   #25
Originally posted by Cyburgs
The parameters for the W4-655SA measured by the german Hifi-DIY-magazine Klang&Ton for example are as follows:
Qt: 0,43
fs: 77,89
VAS: 4,3
anyone know where I can get the drivers in USA? or is there an equal substitute?
gychang
Old 25th May 2007, 01:59 AM   #26
chuck55 is offline chuck55  United States
From Tang-Band's website:
W4-657SC
Free air resonance: 65 Hz
Qts: 0.36
Vas: 6.04 L
W4-655SA:
Free air resonance: 70 hz
Qts: 0.33
Vas: 5.09 L
Old 25th May 2007, 04:24 AM   #27
They are not very different by parameters? Same enclosure should fit for both drivers if we believe Tangband parameters. Ofcourse higher frequencies aren't same.
Old 27th May 2007, 03:49 AM   #28
Mike514ml is offline Mike514ml  United States
Default w4 655 substitute
I'm looking for a substitute driver available over here on the other side of the Atlantic too. This is the closest I can find:
http://www.partsexpress.com/pe/showd...number=264-848
Specs are: fs 70hz, vas 4.86l, qts .37
Datasheet:
www.tb-speaker.com/detail/1230_04/w4-1337sa.htm
The frequency response is different, so it would need a different notch filter. They also pricey - $56.40us (40.62 euros) - but they're the closest thing I can find in the U.S.
Are these a reasonable substitute?
Mike.
Old 3rd July 2007, 05:25 PM   #29
kristleifur is offline kristleifur  Iceland
Originally posted by chuck55
IMHO I would not use the W4-1320. This has a rising FR and is designed for OB.
I think the W4-616 is closer to the W4-655 although probably not as good.
Thanks for the point about the 1320s. If we set the equation up so that the FR is tamed by a theoretical and "perfect" digital EQ, would you estimate that the W4-1320 speaker and its parameters are suited to the Sticks?
Old 5th July 2007, 03:11 AM   #30
RE W4-1320.
Why try to make a driver work that is not suited to the job?
"Cyburgs-Stick" featuring W4-655SAHide this!Advertise here!
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"Music centre" featuring Charlize2 amp dublin78 Class D 0 16th January 2008 04:40 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
