Full Range Speaker Photo Gallery
Old 19th September 2007, 08:54 AM   #621
smallangryboy is offline smallangryboy  United Kingdom
Many thanks !
Old 20th September 2007, 03:46 PM   #622
CLS is offline CLS  Taiwan
Recently I set up a small system with OB & 8in fullranger.
The baffle is 90cmW x 120cmH. The offset driver position is determined by the program "Edge". I haven't got any chance to do any measurement, but in the critical midrange, to my ears they are as smooth as predicted.
The baffle is standing on their simple feet:
I put some soft close cell foam under the feet to make the system more compliant to the floor. I found this actually reduce the vibration.
The drivers were bought from local audio shop named Colin Sound Lab. I cut their dust caps.
I thought of inserting phase plug onto the pole piece. I found a pair of electrolytic caps with perfect diameter. I glued a piece of sheet iron on one end of the cap. However it refused to stay in center of the pole piece, instead, it's induced to the side wall of the voice coil former. Hmmm, maybe I should try a ring instead of a hole circular area....
Anyway, with the dust cap cut off, the lower treble already cleared up a lot. Originally it's a little rough around 2.5k~3k region. Now it's a lot smoother.
Hehe, and the amp is also "OB"
I put 2* RC filters for "baffle step" compensation ahead of 6J5 pre and SE 6H30pi power stage, totally they attenuate 15dB to the mid-high. But it's still not enough, I did additional EQ in the foobar with another 4~5dB. With all these EQ, the balance is now very good, very "full range".
Old 20th September 2007, 05:15 PM   #623
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
....I cut their dust caps.I thought of inserting phase plug onto the pole piece. I found a pair of electrolytic caps with perfect diameter. I glued a piece of sheet iron on one end of the cap. However it refused to stay in center of the pole piece, instead, it's induced to the side wall of the voice coil former. Hmmm, maybe I should try a ring instead of a hole circular area....
Nice baffles and a very interesting looking driver.
To keep the phase plugs from trying to tip over you need to use 2 or 3 spearate pieces of metal. With a single piece, one end of the metal is attracted to the pole piece and the other is repealed.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th September 2007, 10:19 PM   #624
ghpicard is offline ghpicard  Argentina
There is no way that a piece of metal (not a magnet) be repelled by a magnet. The metal piece only tries to align with the force-field lines.
Actually, what's happening is that the sheet is being attracted to the gap because the attraction to the front of the pole piece is not enough to keep it.
The solution is to add magnetic mass so as the attracting force is enough to counter the side-traction. As you say, Dave, to put several pieces of metal, like a gluing a couple of nuts, or screwing a couple of screws will do the trick.
Gastón
Old 21st September 2007, 01:19 AM   #625
frugal-phile(tm)
planet10's Avatar
That makes more sense. My explaination was more a thot experiment based on having the same problem with one of my 1st phase plug experiments -- i used a washer glued to the flat bit of a pair of foam earplugs for a thimble tweeter phase plug.... i was always straigtening it out.
dave
Old 21st September 2007, 02:13 AM   #626
Geoff H is offline Geoff H  Australia
I've used single screws on phase plugs with success. It helps if the screw is recessed into the plug by a few thou.
That pole piece seems to have a centre machined into it. Ideal if it has. A brad driven into the plug with the head left slightly proud, would centre the plug.
Geoff.
Old 21st September 2007, 03:13 AM   #627
Thanks alot for all the tips on phase plug. I'll keep trying.
About the driver, here are the specs:
model name: Colin Sound Lab SP-20
1. 8ˇ¨Full range
2. W fabric surround
3. paper cone
4. paper whizzer
5. 25mm voice coil, paper former
6. coil winding height 4 mm
7. gap width 1.8mm
8. magnetic density > 16000 gauss
9. Gap Height 5mm
10. Fs 45 Hz
11. nominal 8 ohm
12. frequncy range 45 ~ 20000 Hz
13. Qts 0.5
14. SPL 92 dB/w/1m
15. input power 15W max
This driver is no longer available. Now there's a SP-20MKII, with bigger magnet and voice coil and a warmer sound.
ps. The similarity of CSL (Colin Sound Lab) and my user name CLS is just a coincidence. CLS is the abbreviation of my Chinese name.
Old 22nd September 2007, 07:04 AM   #628
skibell is offline skibell  United States
Default Re: Lowther PM6A
the sound is great ! now bass become very very better ( not stronger but more accurate )
Below pic is this boy.
Tks n brgds [/B][/QUOTE]
When building, you will notice that the more time you give to your speakers to burn-in, the more they'll develop a better sound. Plans please!
Old 23rd September 2007, 07:16 AM   #629
Originally posted by Semisentient
Hi guys,
Here is a quick pic of the Zigmahornets (with FE103E drivers) I recently put together.
Originally they were going to be light coloured so I put a maple veneer on them. We then decided to go with a mid tone so I applied a teak stain. Maple does not take stain well! Took much exta work to make them look good... The cabnets are made from 5/8" MDF. I routed a curve on the front two edges so I could wrap one piece of veneer around the front and sides. Plus it gives a nice smooth look...
Anyways this was the first time I had even done anything like this and enjoyed it very much. I discovered I really enjoy woodwork and have since bought a bunch of tools to help (mostly one tool - a Shopsmith).
I picked the Zigmahornet design since I figured it would look good with our new TV. They sound great as well, so now I am thinking of building new speakers for the theatre room! (Although a hushbox for my projector would be the best increase per dollar in sound performance )
Maybe some Voigt Pipes for the theatre... I have a 14' ceiling in there so I can make some huge ones!!!
Thanks, James
Those are very nice, and Shopsmith is a very good tool. Too bad they are not doing that well. Do you have more pics and details of the project?
Old 23rd September 2007, 07:16 AM   #630
scottwilko is offline scottwilko  Australia
here are my steel buschorns more pics coming soon
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
