Full Range Speaker Photo Gallery
Old 9th May 2007, 01:46 PM   #571
scal is offline scal  France
scal's Avatar
Default FE168-E sigma project
hi to all,
i'm starting a project based on the foxtex fe168-e sigma drivers, here some pictures of this project: http://scalblog.blogspot.com/
And somes pictures attached:
Old 10th May 2007, 02:15 AM   #572
Geek is offline Geek
Geek's Avatar
Artistic
Old 16th May 2007, 08:13 AM   #573
scal's Avatar
Smile Update
Originally posted by Geek
Artistic
Updated the blog yesterday, starting to be exiting
(sorry all coments are in french)
Old 16th May 2007, 06:26 PM   #574
Tweeker is offline Tweeker  United States
Sealed box with Fostex FE166ES-R and FT17H tweeter. Quasi current source amp using 51 ohms series resistance. Shown resting on its back as floor monitor.
Be sure your foil hat has a good low impedance ground.
Old 16th May 2007, 06:37 PM   #575
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Crossover?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th May 2007, 08:01 PM   #576
First order, ~.12mH coil in parallel with tweeter for 11k ish, 22 ohm resistor pad also in parallel.
Woofer currently has 15ohms-10uF in parallel with it.
Both these values to be trimmed.
Old 16th May 2007, 08:27 PM   #577
frugal-phile(tm)
planet10's Avatar
Like this?
Old 16th May 2007, 08:41 PM   #578
Yes.
Old 16th May 2007, 09:08 PM   #579
frugal-phile(tm)
planet10's Avatar
What does the R in the woofer circuit do?
I am considering something quite similar for 207 + FT17 -- i was thinking of an extra series cap on the tweeter.
dave
Old 16th May 2007, 09:37 PM   #580
Its a shot at baffle step compensation, the woofer is being run pretty much full range. A straight cap in parallel gives the normal 6dB/oct roll off. All this assumes current source amplifier. Normally tweeters are crossed to with cap, doesnt work out same here. All XO components go in parallel with current source amp.
Full Range Speaker Photo GalleryHide this!Advertise here!
