Full Range Speaker Photo Gallery
Old 16th April 2007, 03:04 PM   #551
Geoff H is offline Geoff H  Australia
A new lease of life for my little Panasonics. The wooden bullets are plain magic. The baffles were cut from scrap and leftovers. Almost a zero cost project, and all the new stuff - glue, bitumous paint, and a handful of screws and nails were on hand.
OK, they need a bit of bass boost, they're only 460mm high and 300mm wide, but mids and top are great. Sharp transients, yet transparent top end.
I have tried two lengths of bullet. I think the shorter ones are better, but I'm not sure why.
Next on the agenda, is too attack the pressed steel frames. I have in mind to glue half round pieces of hardwood to the insides.
Then extract as much bass as I can from a pair of 6x9" car speakers, which are currently wasting space, on a H or U baffle, and PLLXO.
Old 21st April 2007, 11:21 PM   #552
G.Kennedy is offline G.Kennedy  United States
Default FE168e Sigma BIB in Red
More info over in the BIB thread.
I had garbage speakers before .... so these sound like the best speakers on the planet right now. Very happy ... thanks to all who guided me along the path to DIY nirvana.
nirvana .... did someone say Nirvana ... OK ... I am going to go play some ... yahoooo !!!!
Old 22nd April 2007, 12:12 AM   #553
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Is that a Pismo or a Lombard acring as music server? (excuse me if i've asked that before)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd April 2007, 12:23 AM   #554
dave
400 mhz G3 Firewire Pismo ... pretty much the last of the breed.
I use an iMic from Griffin Tech to run the music through the USB instead of the headphone jack. I was getting alot of hum through the mini headphone. Very clean through the iMic.
Old 22nd April 2007, 12:36 AM   #555
frugal-phile(tm)
planet10's Avatar
[QUOTE]Originally posted by G.Kennedy
My Pismo died (again -- in its last incarnation it had parts from 6 different PBs in it -- i'm gonna make one more attempt to resurrect it). My Lombard is still running (OS 9) fine... it has a broken ethernet port and i can't get OS X to run reliably on it)
I
The iMic has limited HF response, and you should put a better USB (or FireWire) DAC on you list of future considerations... i'm still looking for one i can live with (and afford)
dave
Old 22nd April 2007, 12:57 AM   #556
dave
OSX 10.3.9 seems very stable on this unit.
Pretty much every aspect of my system has some quality loss going on. Slowly but surely I will upgrade everything .... just started with the speakers.
Old 22nd April 2007, 03:15 AM   #557
frugal-phile(tm)
planet10's Avatar
That's what i had on the Pismo too
dave
Old 4th May 2007, 03:59 AM   #558
woody is offline woody
I found these Phillips 9762 drivers at a yard sale for $5
They give me almost enough volumn from my 6c45pi amp.
Well tomorow is friday maby I will find another Dynaco
Mark 3 for $1 !
Old 5th May 2007, 02:36 AM   #559
impsick is offline impsick  United States
impsick's Avatar
my little set up...
JBL LSR6328P my babys.
8" carbon fiber composite woofer, bi amp 250w low, 125w high.
jbl's Room Mode Correction.
KRK rokit 5", powered monitor.
and some cheepo JBL2050.
basically for AB'n my mixes.Click the image to open in full size.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 8th May 2007, 03:46 AM   #560
frugal-phile(tm)
planet10's Avatar
Default The latest of the Fonken Family
The GR Fonken (Fonken tuning in a classic golden ratio rectangular box)
We did this because the Fonken is a fiddly box to build. Plans in the Box Plan Library
dave
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
