Full Range Speaker Photo Gallery
Old 29th March 2007, 02:09 PM   #541
lcsaszar is offline lcsaszar  Hungary
Originally posted by gmilitano
Very interesting and nice work. How do they sound?
I have a friend who wanted to try the W3-871S in the Buschhorn MkI.
Did you try the W3-871S in the full size enclosure? When you you say 2/3 of the original dimensions, I assume you are referring to height dimensions only.
Gio.
The Buscchorn has many variants. I chose the MkII for Fostex FE103S, that was 99 cm high, and scaled down every dimension to 3/4. I can't remember precisely, but the original plan was one of these:
http://www.picosound.de/Buschhorn.pdf
http://hometown.aol.de/hphinder/homepage/index.html
The German Tangband dealer had one of these on their site, but now I see only a smaller version, similar to mine:
http://www.speaker-online.de/buschhorn/BHmk2TB.html
Initially it sounded a bit hollow. Then I filled the lower triangle cavity with dry sand, and filled the chamber behind the loudspeaker with mineral wool. Now it sounds quite natural, and its main strength is the transients. The best test was male voice from radio, it reveals every bit of unnaturalness. The internal cable is Cat5 rigid UTP.
I never tried the W3-871S in bigger enclosure. In spite of its dimensions, the low end of the Buschhorn is surprising, even in this scaled down box.
Old 5th April 2007, 06:34 PM   #542
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
Here is a peak at the other cabinets I've been working on. These still need more coats of poly, but i like the look so far.
Josh
Old 5th April 2007, 07:30 PM   #543
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
Josh,
Nice. How do you like them? Did you try driving them with the K-12?
Gio.
Old 5th April 2007, 11:05 PM   #544
edjosh23's Avatar
In my dorm room the only amp I have is the K-12. I am going to build another GC soon for them. They sound great. I much prefer these and the FE127s of the W4-1052SA. These enclosures cannot compare to that of the W4-1052SA, but its midrange that is soo sweet compared to the W4-1052SA. These have no BSC, because they will be for my computer desk, but i think even with BSC they wouldn't be able to match the massive BiTonkens. The K-12 does an OK job powering the WR125s. The WR-125s I think, don't like tubes.
A friend of mine came over to listen to the BiTonkens and bought along an nice Adcom amp. I must admit, the volume control on my preamp was kept the same, and they were just about the same spl. I didn't pull out my spl meter, but we thought it was about the same. Also the bass on the K-12 didn't seem lacking compared to the Adcom.
Thanks,
Josh
Old 9th April 2007, 01:58 AM   #545
Chul is offline Chul  South Korea
Default Bandor unit in a slim TL
While looking at the great pics here, I realized I did similar thing recently. Very lousy finish but still work OK.
Cheers
Chul
Old 9th April 2007, 05:22 AM   #546
tade is offline tade  United States
Send a message via AIM to tade
I listened to the following pair of bitonkens expertly constructed by edjosh23.
They are delightful as are every full range design built by this fellow. These bitonkens have a large amount of bass when compared to the larger frugel horns, however the bass may not have been subjectively quick as the horns. I don't like the W4-1052SA. I don't think that polypropylene does a good enough job in terms of delicacy and immediacy. Considering also that this is a low efficiency design when compared to the horns which i listen to regularly this loss of detail may be expected.
The bitonken concept is excellent and the bipolar design makes for ample bass. I would love to see some paper coned high efficiency drivers in this driver's stead. or perhaps the bamboo fiber coned version of this driver.
I really enjoyed listening to these speakers for their smoothness, generous sound stage, and quick ample bass.
Old 9th April 2007, 07:15 PM   #547
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Good to hear.
Josh got the idea (and the name -- he asked my permission) from my BiFonken for the FE127e/ That in turn came from the Bipole miniOnken for the FR125s. I gave Josh a few pointers on the design goals & philosophies behind the miniOnken/Fonken style design, and i'm glad he came up with something that works (altho it will be imited by the driver's performance -- Josh too has expressed that he is not as happy with the TB as he'd like)
Recent measures of the Fonken indicate bass to the low 50s, a bipole would get to the same place with more authority... that only really gives us a clue to what the TBs might be capable of. A Frugel-Horn, properly positioned in a corner, with full deflectors & supra-baffle, just reaches into the same range. IJosh's Frugel-Horns have FE127 so we really have an unknown extension there.
The discussion i had with Josh also helped some ideas gel for BiFonken Mark II, which is just starting to make the transition from paper to reality.
This has been further fueled by th 3rd resurrection of the Bipolar diyRef ML-TLs... we finally got a "stand" mechanism that works cosmetically. The bass on these isn't as tight as the Fonkens, but the overall spaciousness and the weight of the botton illustrates some of the things bipole does well. And these don't (currently) have the good drivers in them.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th April 2007, 07:16 PM   #548
frugal-phile(tm)
planet10's Avatar
And here the pair. Hopefully this one helps communicated how diminuative these are.
Old 9th April 2007, 07:27 PM   #549
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
On an aside, is that the Apex Jr woofer I see in the corner?
planet10 needs your help:
Let's help Ruth and Dave
Old 9th April 2007, 07:56 PM   #550
frugal-phile(tm)
planet10's Avatar
yes... push-push of course. Only plays with the HT.
dave
Full Range Speaker Photo GalleryHide this!Advertise here!
