Full Range Speaker Photo Gallery
Old 3rd March 2007, 01:16 PM   #491
jives11 is offline jives11  United Kingdom
jives11's Avatar
[QUOTE]Originally posted by Phergus_25
/QUOTE]
Originally posted by gychang
looks like a serious furniture making....
gychang
Fantastic design, please post pictures when they're done. The profile suggests a figure perhaps
Old 5th March 2007, 03:28 PM   #492
djn is offline djn  United States
djn's Avatar
This is a project my daughter and I built for her dorm
Making cabs
All the hardware
Gluing and Veneering
Set up in her dorm driven by a Crown D150 and her laptop
Old 7th March 2007, 11:15 PM   #493
audio_hobbyist is offline audio_hobbyist  Canada
Default Re: Sp-200x speaker
Originally posted by sumacSK
Hi all,
Here is my MLTL speaker using Monacor SP-200X fullrangers and Eminence APT80 tweeters. I designed it using Martin King's tool. I can hardly imagine something better for the price (you can get those monacors for 25 euro in my country...). Here is some pictures.
Martin
SumacSK: I noticed you have the tweeter located below the fullrange. I read somewhere that this configuration causes the overall radiation axis to be slightly upward as opposed of downward (which is a good thing). Did you noticed this effect?
Old 7th March 2007, 11:28 PM   #494
Ray Collins is offline Ray Collins  United States
djn,
Nice job....I am sure she appreciates it!!!
Ray
Old 11th March 2007, 02:09 PM   #495
Taiga is offline Taiga  Sweden
Taiga's Avatar
Hello. My biggest build so far. I got a lovely pair of Coral Flat 8 II and thought a construction called AoE Horns in a Swedish HiFi magazin promising. It was constructed around McFarlow 8" and a tweater both nowaday obsolete. Calculations gave smaller changes. I first tryed with only Corals but didnīt like the upper end and very hard sweet spots. A Sonab tweater and 3īrd degree cut at 8000 (just for try something). The result was awesome. They are now my reference in other builds around BL horns. They should have a better filter because there is a lack in center image around the cut but my mind is still focused on newer projects. Another area of improvement is building with 24 mm ply instead of my 19 mm board since small resonans problems exist.
Kind regards
Sound of silence is stressing
Old 11th March 2007, 07:56 PM   #496
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Looks like you built of some sort of particle board? Just switching to ply of the same thickness would probably be sufficient.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2007, 09:34 PM   #497
Taiga's Avatar
To hot for starting. Couldnīt wait for better material and to stubborn to learn of mistakes. Yes your right that 19 mm ply is sufficient but then probably with stabilisation ribs somewere in mouth. I think a large horn are very sensitive for standing waves across the side panels in that area. When feeling with the hand you notice serious vibrations even on hard board like ply. Harder material is in my schoolbook with higher freqvency but lower amplitude. You know what you have but not what you get. Am i right? Perhapes the mouth isnīt as sensitive for colorization as earlier parts in the horn though.
Thanks for your interest
Old 11th March 2007, 09:50 PM   #498
frugal-phile(tm)
planet10's Avatar
My attitude is that it is hard to have too much bracing
In the horn pictured above i can see where i'd add at least 4 braces.
dave
Old 11th March 2007, 10:15 PM   #499
Phergus_25 is offline Phergus_25  United States
Send a message via AIM to Phergus_25 Send a message via Yahoo to Phergus_25
Toshiba Sd-9200
JA Audio tube Pre
Pioneer SA-5200
Austin A126s
Old 11th March 2007, 11:02 PM   #500
frugal-phile(tm)
planet10's Avatar
is there a reason for the odd mounting orientation of the driver?
dave
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
