Full Range Speaker Photo Gallery
Old 7th November 2006, 10:23 PM   #401
gychang is offline gychang  United States
Default Re: Re: another BIB (bigger is better)
Originally posted by one1speed
Nice! Care to share details? Driver, etc?
take a look at the details and more photo here.
http://www.diyaudio.com/forums/showt...threadid=89831
Old 8th November 2006, 05:39 AM   #402
audiophile36 is offline audiophile36  United States
audiophile36's Avatar
Here is what I'm currently listening to at the moment.These are Fostex Fe126e based OB and I must say the overall sound is better than any box I tried them in so far.What I really like is the 3- D sound stage you get from OB and the the phase correct bass reproduction.In my small room bass is good enough to not need a sub for my musical tastes.[IMG]Click the image to open in full size.[/IMG]
If it sounds good it is good!
Old 14th November 2006, 06:27 PM   #403
pekar is offline pekar  United States
pekar's Avatar
My bookshelf Del Sol.
larger pics and discussion via -
http://www.diyaudio.com/forums/showt...threadid=90212
Old 14th November 2006, 10:34 PM   #404
thomaseliot is offline thomaseliot  Europe
Default Singular from BD design
Quote from BD design site:
"The basic design for the SINGULAR was initiated by Onur Ilkorur. The SINGULAR is not a bass reflex design, which is only efficient for only half an octave. It is not a transmission line needing a lot of damping material to tame resonances. Neither is it a TQWP or ML-TQWP. Instead, it is a combination of all these loading systems, resulting in a wide-band resonator effective from 40Hz to 250Hz."
Old 15th November 2006, 07:20 AM   #405
felixx is offline felixx  Romania
felixx's Avatar
Nice design but.........be honest.....what is the lowest freqvency in large terms (+/_ 3db) who can achieve?
I ask that because is very hard to not need another aditional woofer to have a good and nice reponce ...you know...the real full range.
Thx.
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 15th November 2006, 08:51 AM   #406
Thx.
Bass is quite good, not measured, but I trust BD specs. I experienced best results with at least 50w power amp, while with a low power amp these speakers sound too brite with lack of bass, even if FE206E is rated 96dB.
Enclosure inside from http://www.woebking.net/cms/index.ph...g2_itemId=1850
Old 20th November 2006, 11:45 PM   #407
Geoff H is offline Geoff H  Australia
One of my Wharfedales Super 10 RS/DD
Old 20th November 2006, 11:53 PM   #408
Front view, showing enlarged tweeter cone with foam damping ring to reduce edge resonance, and 3" dust cap. Cloth surrounds treated with bitumous "stuff" I treated the cones, as advised by Norm.
The mods were carried out 27 years ago, by Norm Edge, Melbourne Australia. Including 8 ohm vc. and spider. They are now 40 years old.
Still working extreamly well.
Mounted on a test baffle/ corner enclosure.
Old 21st November 2006, 02:29 AM   #409
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Those really should be front mounted or have a 45 degree champher on the opening....
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st November 2006, 07:37 AM   #410
err, yeah, they are a bit rough n ready. They were in cupboards for about 15 years, I was in a hurry to make some nice sounds. And my new landlady said I could play my records as loud as I like!
They should really be in 3.5 cub ft enclosures, or TLs, which is where they look like heading, once I learn a bit more about them.
On that, Wharfedales should be mounted on the rear, unless you want to machine the baffle to suit, or as I have on my other set, 1/4 lb of silastic! The rear of the rim is not flush. That's why they have the green felt gasket on the front.
Has anyone tried these in QWTLs?
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
